Sherman install
Goto page 1, 2  Next
pomester
PostPosted: Thu Feb 08, 2018 8:01 pm    Post subject: Sherman install Reply to specific post Reply with quote
In case there's interest here's a pictorial of the Sherman install that consumed a bit of time over the past few days -
I have a TO30 that needed engine work that necessitated pulling the engine - I had scored an Sherman combination 3-4 years ago off of eBay and had cleaned it up, inspected, and procured a few minor items (shims and gaskets and a seal) in case this day would ever come -
engine pulled, I went ahead and removed the steering pedestal, starter mechanism, brake and clutch cross shafts, and input shaft to clear the area - nasty oily (leaking rear main seal on the engine) - I later went ahead and pulled the shift cover so I could see what was going on with the preload on the bearing
a quart of kerosene and half a can of brake cleaner later and the area was fit to work in
The mounting flange and shims and gasket - to make a long story short, I didn't need the shims and I also made a gasket out of thin material to get the input shaft acceptably close to the bearing
flange installed and Sherman about to be bolted into position
after a couple of times in and out I tightened things so to locate the shifter hole - I was worried about this aspect, large holes in heavy metal is a weak point in my skill set -
I used a bit of angle iron and machinist square to locate the center of the hole
removed the transmission again and drilled a pilot hole and then went with a bimetal hole saw
I was pleasantly surprised at how straightforward/easy it was - I cleaned up the hole with a grinder, shot a bit of gray primer on the area and put the Sherman back in position - I'm satisfied with the result
for future reference, this hole is centered at 2-7/16" down from the pedestal machined surface and 14-1/8" forward of the transmission flange
filled with GL-1, new seal on the input shaft, shifter in position - the Sherman and the piece it replaced -
tomorrow I'll put the starter (needs work) and cross shafts back - also trying to move ahead on the engine...
el6147
PostPosted: Thu Feb 08, 2018 8:28 pm    Post subject: Re: Sherman install Reply to specific post Reply with quote
The Gl-1 that you used was what brand and what weight? and where did you purchase it?
email is also open. thanks
pomester
PostPosted: Thu Feb 08, 2018 8:43 pm    Post subject: Re: Sherman install Reply to specific post Reply with quote
NAPA has it in quarts, gallons, and 5 gallon buckets - I did a good clean and refurbishment of the trans/hydraulic/rear end two years ago and used this fluid in those reservoirs -
pomester
PostPosted: Thu Feb 08, 2018 8:47 pm    Post subject: Re: Sherman install Reply to specific post Reply with quote
el6147
PostPosted: Thu Feb 08, 2018 9:01 pm    Post subject: Re: Sherman install Reply to specific post Reply with quote
I,m looking for 140, I checked at Napa about a year ago and was told that 140 was not
available. thanks
John Deere D
PostPosted: Thu Feb 08, 2018 9:36 pm    Post subject: Re: Sherman install Reply to specific post Reply with quote
Thanks for the great pictures:
I own a TEA-20 and have a Sherman to install someday:
Bob...
pomester
PostPosted: Fri Feb 09, 2018 3:55 am    Post subject: Re: Sherman install Reply to specific post Reply with quote
CVPost-el6147 wrote:
I,m looking for 140...
Have you checked with John Deere? I used to get that sort grease there to lubricate the rollers on a 40 crawler
el6147
PostPosted: Fri Feb 09, 2018 6:36 am    Post subject: Re: Sherman install Reply to specific post Reply with quote
exactly what I need it for , I think I checked once with John Deere.
pomester
PostPosted: Fri Feb 09, 2018 9:02 am    Post subject: Re: Sherman install Reply to specific post Reply with quote
I hear John Deere 'corn head grease' mentioned sometimes as a thick flowable oil for use in places like steering gear boxes where seals have deteriorated and lighter lubricants leak out - -
have you the special gun with fitting that is used for those crawler rollers?
el6147
PostPosted: Fri Feb 09, 2018 11:05 am    Post subject: Re: Sherman install Reply to specific post Reply with quote
yes its the Lincoln gun, Would prefer to stay with GL1, that is what I've always used and I
have no leaks. I have located a place that can get it for me in a 5 gal bucket, it's just
that it is about a 120 mile round trip for me. Thanks
Kirk-NJ
PostPosted: Sat Feb 10, 2018 9:15 am    Post subject: Re: Sherman install Reply to specific post Reply with quote
Looks good. Did you also install a rubber grommet at the hole?
pomester
PostPosted: Sat Feb 10, 2018 3:32 pm    Post subject: Re: Sherman install Reply to specific post Reply with quote
I have not, but it is on the 'incidentals' list - I'm not sure where to find one that will fit, it would need to be wide to cover the casting thickness - I'll see what the local hardware offers, maybe take two and glue them together, or just cut the lip off one side and glue it to the case from the outside - dunno -
have you a suggestion?
David
Kirk-NJ
PostPosted: Sat Feb 10, 2018 5:36 pm    Post subject: Re: Sherman install Reply to specific post Reply with quote
Hit the link
link
pomester
PostPosted: Sat Feb 10, 2018 6:36 pm    Post subject: Re: Sherman install Reply to specific post Reply with quote
How about that? - never would've guessed that item was available and labeled as such - thanks
David
Boss Hog
PostPosted: Sun Feb 11, 2018 5:58 am    Post subject: Re: Sherman install Reply to specific post Reply with quote
Have you already purchased the oil?
I use 15W40 in my tractor. Doesn't get as thick in cold weather.
Goto page 1, 2  Next
Page 1 of 2
