TO35 Separate differential from transmission
RedGreenGuy
PostPosted: Fri Feb 09, 2018 12:18 pm    Post subject: TO35 Separate differential from transmission Reply to specific post Reply with quote
Finally time to fix it. As explained couple years ago I had water (condensation) in differential that froze and cracked the case and lid upon startup. Ready to split the differential from the tranny. Have lid off and trying to remove hydraulic pump. Got cotter key out of shaft, slid collar back to remove shaft. Still can't get shaft out. Almost but not enough play to remove. What needs tapped or loosened a 1/4 inch? I have service manual from YT. But no instructions on how to split tranny from differential. Don't want to damage tranny. Tractor is early 1955
Steve@Advance
PostPosted: Fri Feb 09, 2018 1:59 pm    Post subject: Re: TO35 Separate differential from transmission Reply to specific post Reply with quote
Once the collar is slid back, the shaft should pull forward, up and out.
Pump Service
miner09
PostPosted: Fri Feb 09, 2018 3:03 pm    Post subject: Re: TO35 Separate differential from transmission Reply to specific post Reply with quote
Keep moving collar back and forth. Sometimes they don't go back all the way first time.
Steve@Advance
PostPosted: Fri Feb 09, 2018 5:00 pm    Post subject: Re: TO35 Separate differential from transmission Reply to specific post Reply with quote
Been a while since I've been in one,
but got to thinking, maybe the PTO shift collar needs to be slid back also?
steve19438
PostPosted: Sat Feb 10, 2018 2:04 am    Post subject: Re: TO35 Separate differential from transmission Reply to specific post Reply with quote
is it possible the ice may have bent something ? i did that 10 years ago but my memory of it has long since faded.
RedGreenGuy
PostPosted: Sat Feb 10, 2018 4:48 am    Post subject: Re: TO35 Separate differential from transmission Reply to specific post Reply with quote
Thank You! Got the shaft out, now to get it split.
John Deere D
PostPosted: Sat Feb 10, 2018 6:38 am    Post subject: Re: TO35 Separate differential from transmission Reply to specific post Reply with quote
I had to split my MF 35 last summer:
Possibly pictures are of assistance:
Bob...
John Deere D
PostPosted: Sat Feb 10, 2018 6:59 am    Post subject: Re: TO35 Separate differential from transmission Reply to specific post Reply with quote
I had to split MF 35 (1963 model) last summer, 2017:
Replaced HYD Pump and coupling:
Possibly pictures are of assistance?
If Coupling is seized on out put shaft of Transmission, separate Transmission, out put shaft and coupling as one unit from Diff:
Bob...
RedGreenGuy
PostPosted: Sun Feb 11, 2018 6:15 pm    Post subject: Re: TO35 Separate differential from transmission Reply to specific post Reply with quote
Thanks again to all. Got the pump out. Sump has lots of slime in it. Replacement case will start clean. I have read where YTers were discussing an oil filter screen in the lower part of this case. This tractor does not have it. Can I install one in the new case?
RedGreenGuy
PostPosted: Sun Feb 11, 2018 6:23 pm    Post subject: Re: TO35 Separate differential from transmission Reply to specific post Reply with quote
I might add plan to clean her up and paint correct green/gray colors. I purchased this tractor from FILs estate. He had for 8 yrs and I for 15. It was brush painted gray. Must have used a broom for a brush. Deep heavy brush marks, Painted over dirt and grease. Had to use a chisel to get paint/grease off bolt heads. A least it did not get rusty.
