1600 Power Beyond Setup
Goto page Previous  1, 2
DTK
PostPosted: Wed Feb 14, 2018 10:45 am    Post subject: Re: 1600 Power Beyond Setup Reply to specific post Reply with quote
Hi, I just was wondering where you go to get. Hyd. Lines made like that. Beautiful job. Thanks DtK
oliverkid
PostPosted: Wed Feb 14, 2018 1:55 pm    Post subject: Re: 1600 Power Beyond Setup Reply to specific post Reply with quote
There are valves out there that only have two ports, one in one out, that claim they can be used for power beyond and they will work, But your results will vary. Without the third port as a true tank port pressure builds in the drain passages at the ends of the spools and if it is high enough it will cause the spools to shift and your loader or what ever you are operating with the power beyond valve will drift one way or the other. I have had three tractors that this has been done on by the owners and had to install a bypass valve around the valve to stop the drift when the tractors were being used for other things. Hope this explains it.
oliverkid
PostPosted: Wed Feb 14, 2018 1:56 pm    Post subject: Re: 1600 Power Beyond Setup Reply to specific post Reply with quote
Dad made them.
random_farmhick
PostPosted: Thu Feb 15, 2018 8:34 am    Post subject: Re: 1600 Power Beyond Setup Reply to specific post Reply with quote
Looks good, only thing I might do different is where your quick couplers are for your loader valve, put 90's on there so they point forward instead of up. You'll have less problems in the long run with wearing out couplers and o rings.
Don-Wi
PostPosted: Mon Feb 19, 2018 12:24 am    Post subject: Re: 1600 Power Beyond Setup Reply to specific post Reply with quote
That's what I need to do to my 1600. Maybe I can get to it this summer when I take care of a few other issues. That looks clean.
Donovan from Wisconsin
Page 2 of 2
