70 Series injection pumps
Don Rudolph
PostPosted: Mon Feb 19, 2018 6:40 am    Post subject: 70 Series injection pumps Reply to specific post Reply with quote
Is an injection pump from a 1070 the same as an injection pump from an 1175? Thanks, Don
Case Nutty 1660
PostPosted: Mon Feb 19, 2018 7:51 am    Post subject: Re: 70 Series injection pumps Reply to specific post Reply with quote
They will bolt on fine Don, but the 1175 pump will be set to put more fuel out than the 1070, that can be dialed back easy enough, if you do only turn 1/8" of a turn at a time, it is easy to get them way out of adjustment
cnt
Dieseltech
PostPosted: Mon Feb 19, 2018 9:36 am    Post subject: Re: 70 Series injection pumps Reply to specific post Reply with quote
Look at the PES6A number, just after the A is the plunger MM size, 70 for 7MM, 80 is 8MM, ETC. Bosch A size pumps largest stock plunger size is 10MM which would show as 100. There are also half sizes too, 75, 85, and 95 are common. Turbocharged engines are usually 9mm and larger for higher full load fuel delivery.
Roger Link
PostPosted: Mon Feb 19, 2018 10:43 am    Post subject: Re: 70 Series injection pumps Reply to specific post Reply with quote
I believe the pump camshaft has a smaller hub where the gear bolts on also. Every thing will fit though.
Dieseltech
PostPosted: Mon Feb 19, 2018 1:12 pm    Post subject: Re: 70 Series injection pumps Reply to specific post Reply with quote
Bosch PESA 1000 series pumps use the small 17MM drive cam/hub taper, takes a 19MM wrench for the nut. PESA 2000 and 3000 pumps use the larger 20MM cam/hub taper, has a 22MM wrench size nut. Case three bolt pump drive gear will fit both hubs.
Paul A Young
PostPosted: Mon Feb 19, 2018 7:24 pm    Post subject: Re: 70 Series injection pumps Reply to specific post Reply with quote
1175 has a 9mm pump and the 1070 has a 8.5mm. I think, Paul
