sureseal
Dale2
PostPosted: Wed Feb 21, 2018 10:21 am    Post subject: sureseal Reply to specific post Reply with quote
Can someone tell me how and where to put sure seals in a 2n tractor. I am getting conflicting information on where they go. Do you have to remove the axel bearing to install them?
thanks
Dale
JMOR
PostPosted: Wed Feb 21, 2018 11:41 am    Post subject: Re: sureseal Reply to specific post Reply with quote
go here: (copy & paste & remove the *)
http://www.nt*ractorcl*ub.com/howtos/pdfs/Servicing-9N-2N-Rear-Axles.pdf
grizz02
PostPosted: Wed Feb 21, 2018 11:58 am    Post subject: Re: sureseal Reply to specific post Reply with quote
no you pack the bearing with grease slide the seal down the axle and try to tap it into place I say try because they can be difficult at best I made a seal driver off a oxygen bottle safety cap I cut the top off leaving the threaded end intact it fit the seal perfectly
Dale2
PostPosted: Wed Feb 21, 2018 12:01 pm    Post subject: Re: sureseal Reply to specific post Reply with quote
Thanks for the help. That cleared up a lot. But do you think that blocking the oil flow to the bearing is a good ideal? I understand I need to pack the bearing and I know some of the tractors have a grease fitting to grease the outer wheel bearing but no one is going to know this tractor has sure seals in it. Just seams like it fixed one problem but created another.
Thanks again for the help
Dale
JMOR
PostPosted: Wed Feb 21, 2018 1:01 pm    Post subject: Re: sureseal Reply to specific post Reply with quote
CVPost-Dale2 wrote:
(quoted from post at 16:01:35 02/21/1Cool Thanks for the help. That cleared up a lot. But do you think that blocking the oil flow to the bearing is a good ideal? I understand I need to pack the bearing and I know some of the tractors have a grease fitting to grease the outer wheel bearing but no one is going to know this tractor has sure seals in it. Just seams like it fixed one problem but created another.
Dale
Tens of millions of cars & trucks have been on the roads for a lifetime with wheel bearings packed with grease without being flooded in differential grease. I see no problem here.
Bill M. From Illinois
PostPosted: Wed Feb 21, 2018 5:48 pm    Post subject: Re: sureseal Reply to specific post Reply with quote
I used a cut off piece of PVC to drive bearing on. Maybe 3 ID inch piece, cant remember for sure. It can be a bear getting started straight.
