Installing Char Lynn on WD45 help
tomturkey
PostPosted: Fri Feb 23, 2018 3:18 pm    Post subject: Re: Installing Char Lynn on WD45 help Reply to specific post Reply with quote
Couplings with hole for roll pins into both shafts in and out. Mine were connected to a power steering pump with reservoir that was mounted off the front of the block and vee belted to the water pump. There was no priority valve as it was complete system. I've never seen one plumbed into the tractor hydraulics. gobble
orangepower
PostPosted: Fri Feb 23, 2018 4:31 pm    Post subject: Re: Installing Char Lynn on WD45 help Reply to specific post Reply with quote
It'd be a lot cheaper and easier to find a complete used outfit somewhere like eBay from a parts tractor. We bought one a few years ago with pump, reservoir, brackets, double pulley, etc. Think it was around $350. Even came with the modified throttle rod and steering shaft couplers. It sure makes it more fun to drive now. Like having a new tractor.
Butch(OH)
PostPosted: Fri Feb 23, 2018 5:46 pm    Post subject: Re: Installing Char Lynn on WD45 help Reply to specific post Reply with quote
As they said you need to buy or make the couplers for the steering shaft, you have to modify the throttle shaft. You have to make a bracket that goes to the frame that is strong enough to resist the generated torque. You also need to purchase a pump, an older Ford powersteering pump is what a lot of guys use. You need to build the mounting for the pump and figure out how to rive it from the crankshaft, you can not run it with a flow divider on a WD45. plus of course hoses
Tramway Guy
PostPosted: Fri Feb 23, 2018 8:58 pm    Post subject: Re: Installing Char Lynn on WD45 help Reply to specific post Reply with quote
You drive it from a separate pump driven from the crankshaft pulley. The flow from the built-in tractor pump is insufficient to supply the torque generator, and it will stop when you push in the foot clutch.
Replace the crankshaft pulley with a two-groove pulley and install a power steering pump somewhere above the thermostat area.
Ken C.
PostPosted: Sun Feb 25, 2018 9:39 am    Post subject: Re: Installing Char Lynn on WD45 help Reply to specific post Reply with quote
Thanks for the info, it helps me decide.
Ken
Ken C.
PostPosted: Sun Feb 25, 2018 9:46 am    Post subject: Re: Installing Char Lynn on WD45 help Reply to specific post Reply with quote
Thanks, in order to change the front pulley (to add another groove) would I need to remove the radiator?
Ken C.
Ken C.
PostPosted: Sun Feb 25, 2018 9:48 am    Post subject: Re: Installing Char Lynn on WD45 help Reply to specific post Reply with quote
Thanks, did you use a Char-Lynn Torque Generator?
Ken C.
Ken C.
PostPosted: Sun Feb 25, 2018 9:56 am    Post subject: Re: Installing Char Lynn on WD45 help Reply to specific post Reply with quote
Thanks, It sounds like most folks just have the shaft couplers. Where do they come from or where can you get them?
Ken C.
Butch(OH)
PostPosted: Sun Feb 25, 2018 2:28 pm    Post subject: Re: Installing Char Lynn on WD45 help Reply to specific post Reply with quote
You have to unbolt the entire front support and slide it forward. I did our WD a bit differant than most. I made a 2 groove pulley for the generator and drive the power steering pump from the front groove. Back when I did it the 2 grove crank pulleys were like gold, now they are reproduced
orangepower
PostPosted: Mon Feb 26, 2018 4:26 pm    Post subject: Re: Installing Char Lynn on WD45 help Reply to specific post Reply with quote
Yes. It has a Char-Lynn tag on it. I'm pretty sure you'll have to remove the radiator to have enough room to get at the crank pulley. I don't see the need to remove the entire front bolster. Your hand crank rod should slide forward enough to give you room. Pulley is held in place by set screws. Spray the old pulley down with P Blaster and let it soak. It'll probably be stuck good if it's never been off. Would be a good time to replace the crank seal while you have the pulley off. Good luck.
