Add on power steering for a 430
Goto page 1, 2  Next
flatpkr
PostPosted: Mon Mar 05, 2018 1:35 pm    Post subject: Add on power steering for a 430 Reply to specific post Reply with quote
I have a Case 431T, general purpose tractor, that doesn?t have power steering. Is it possible to add on now? I have a parts manual that shows
the pump and related parts. This is a 1961 model with a 188 CI Diesel engine. I don?t see an opening on the engine to install the pump though.
Jim
Cariboo4x4
PostPosted: Mon Mar 05, 2018 3:12 pm    Post subject: Re: Add on power steering for a 430 Reply to specific post Reply with quote
I have the diesel 188 in my Case W3 (530). It has power steering and pump is mounted just below generator. There is a approx 3' diameter hole surrounded by 3 bolt holes in front engine cover for pump to be inserted. My generator actually mounts on top of my power steering pump. The pump has a gear that meshes with of gears under the front cover.
Currently my pump is worn out and trying to find a replacement. Its hard item to find. I thought of removing gear on pump so it does not turn and fabbing another pump to run off fan belt yet that would be my last last resort. It would be a tight fit because I have a loader to put back on tractor.
I can take photos of my current set-up before and after I put it back together.
Adirondack case guy
PostPosted: Mon Mar 05, 2018 4:02 pm    Post subject: Re: Add on power steering for a 430 Reply to specific post Reply with quote
Gee, I thought that I had the only Turbo Charged 431. HeHe. Your tractor would have had a pump that bolted to the RH side back of the engine timing cover and powered a CharLynn rotary motor which was spliced into the steering shaft and mounted on a side rail on the LH side of the tractor. The generator mount, bolted to the pump housing.
Loren
flatpkr
PostPosted: Mon Mar 05, 2018 5:31 pm    Post subject: Re: Add on power steering for a 430 Reply to specific post Reply with quote
Does 431T mean turbo diesel? Or are you just pulling my leg?
Jim
Cariboo4x4
PostPosted: Mon Mar 05, 2018 5:33 pm    Post subject: Re: Add on power steering for a 430 Reply to specific post Reply with quote
CVPost-flatpkr wrote:
(quoted from post at 18:31:13 03/05/1Cool Does 431T mean turbo diesel? Or are you just pulling my leg?
Jim
I'm pretty sure he is pulling our legs haha,
CKRICHARD
PostPosted: Mon Mar 05, 2018 6:38 pm    Post subject: Re: Add on power steering for a 430 Reply to specific post Reply with quote
Go to eBay look up case backhoe power steering pump and you will find lots. This is also a good way to find brake parts, radiators for 430 530 because there is aftermarket support for case backhoes.
Richard
dkeav
PostPosted: Mon Mar 05, 2018 9:04 pm    Post subject: Re: Add on power steering for a 430 Reply to specific post Reply with quote
He's not pulling your leg, because he modified his 430 with a turbo, but there was no factory option. Look up his posts that document it though, its worth a hearty chuckle in the Tim Allen more powah!! kinda way.
The stock 430 setup on the wide fronts used two cylinders which are now unobtanium. Like Loren said though, you can use the power steering setup off of say a 300 with the charlynn pump/cylinder and just splice it into your steering shaft.
Cariboo4x4
PostPosted: Tue Mar 06, 2018 11:52 am    Post subject: Re: Add on power steering for a 430 Reply to specific post Reply with quote
That's great info to know!
Adirondack case guy
PostPosted: Tue Mar 06, 2018 3:07 pm    Post subject: Re: Add on power steering for a 430 Reply to specific post Reply with quote
His 431 is prior to hydrostatic steering. The early 4-630s used the Charlinn hydro motor units mounted down on the frame rail or up under the dash with the shaft connected to it. The punp was mounted on the RH of timing housing and had a reservoir mounted above the pump back on the block.
Thanks to Bro. some pics should follow.
Loren
Case Nutty 1660
PostPosted: Tue Mar 06, 2018 3:29 pm    Post subject: Re: Add on power steering for a 430 Reply to specific post Reply with quote
cnt
Adirondack case guy
PostPosted: Tue Mar 06, 2018 3:36 pm    Post subject: Re: Add on power steering for a 430 Reply to specific post Reply with quote
On my tractor the T means Turbo Charged.
To add a Power Steering pump you will need to remove the cast pedestal that the generator mounts to. It is held to the timing cover with 3 3/8" bolts, and then bolt in a pump that utilizes those 3 bolts, and has a mounting flange for a different generator mount.
Loren
Cariboo4x4
PostPosted: Tue Mar 06, 2018 3:56 pm    Post subject: Re: Add on power steering for a 430 Reply to specific post Reply with quote
CVPost-Adirondack case gu wrote:
(quoted from post at 16:36:41 03/06/1Cool On my tractor the T means Turbo Charged.
Loren
Very cool! Must have some serious power!
Cariboo4x4
PostPosted: Tue Mar 06, 2018 3:57 pm    Post subject: Re: Add on power steering for a 430 Reply to specific post Reply with quote
Heres where my power steering pump attaches to diesel 188 engine:
Cariboo4x4
PostPosted: Tue Mar 06, 2018 4:03 pm    Post subject: Re: Add on power steering for a 430 Reply to specific post Reply with quote
Here is the remote reservoir on left and bracket that bolts to pump on right sitting on top of generator. I wish my engine was nice and clean for photo!
Cariboo4x4
PostPosted: Tue Mar 06, 2018 4:17 pm    Post subject: Re: Add on power steering for a 430 Reply to specific post Reply with quote
I started another post the other day with photos of my pump.
Goto page 1, 2  Next
Page 1 of 2
