Loader on a 1370 Hyd question
Greg Hammel
PostPosted: Tue Mar 06, 2018 8:00 pm    Post subject: Loader on a 1370 Hyd question Reply to specific post Reply with quote
Putting a loader on a 1370 . loader has a 2 spool valve on it,can I get a hyd supply ,like power beyond ,or do I have to use the tractor remotes
1370rod
PostPosted: Wed Mar 07, 2018 5:47 am    Post subject: Re: Loader on a 1370 Hyd question Reply to specific post Reply with quote
If you like to keep things simple, the best way I think is to just feed it from the tractors remote valve. Yes you do give up a circuit, but if you ran all the hyd flow through your 2 spool valve it would have to be equipped with a relief valve. Also your valve would need to be able to withstand the back pressure caused by operating the tractors remotes or 3 pt. The valve would be plumped in after the flow divider and before the remote valve. Rod
Greg Hammel
PostPosted: Thu Mar 08, 2018 5:14 pm    Post subject: Re: Loader on a 1370 Hyd question Reply to specific post Reply with quote
ok thanks Rod that's what im going to do
