FL head type rocker arm and push rods
Gord1955
PostPosted: Thu Mar 08, 2018 1:14 pm    Post subject: FL head type rocker arm and push rods Reply to specific post Reply with quote
Will these fit on a 55 Major, they are a heavier push rod and the rockers are in nice shape... thinking about swapping the setup for my 55's
JLMac
PostPosted: Thu Mar 08, 2018 4:36 pm    Post subject: Re: FL head type rocker arm and push rods Reply to specific post Reply with quote
Don't think they will work on a Major block. Hopefully others will chime in.
Gord1955
PostPosted: Thu Mar 08, 2018 6:57 pm    Post subject: Re: FL head type rocker arm and push rods Reply to specific post Reply with quote
Look like they would but all the FL valves have caps on them and the Major only on half the valves, could be a problem, push rods seem the same length but a little more skookum.
Majorman
PostPosted: Fri Mar 09, 2018 12:59 am    Post subject: Re: FL head type rocker arm and push rods Reply to specific post Reply with quote
The FL head will fit but there is a problem. The valve springs were far
stronger than the Major and the FL tractors had uprated cam followers, cam
shaft with a single bolt fixing, timing gears as well as the rockers. Even
with all the upgrades Supers with FL heads would eat cam followers and cam
shafts back in the day. Our dealership changed a lot on relatively new
tractors.
One of the first questions I answered on this board twenty years ago was to
identify "rings" found in a Super Major 5000 sump. They were from cam
followers where the centre had been worn out. I got a new set and a new
camshaft and sent over to the US and it was not cheap.
I would stick with what you have.
Gord1955
PostPosted: Fri Mar 09, 2018 7:30 am    Post subject: Re: FL head type rocker arm and push rods Reply to specific post Reply with quote
Thanks for your reply but yes, I read up on the head and that is why I didn't use it, I only wanted to use the rocker arm assembly and push rods if they would work.- Kinda like my old Harley, if there is something that is a better upgrade than the original, well you know:)
Majorman
PostPosted: Sat Mar 10, 2018 9:35 am    Post subject: Re: FL head type rocker arm and push rods Reply to specific post Reply with quote
You may find the push rods rub on your head depending on how early your
tractor is. The rockers changed over the years, the main change came in 1957.
Gord1955
PostPosted: Sat Mar 10, 2018 12:32 pm    Post subject: Re: FL head type rocker arm and push rods Reply to specific post Reply with quote
Mine is a 55 Major, but for an hours work if that I can check it out...mine are a little worn and these ones are in great shape so it's worth the time, all rebuilt with very few hours on it and now to put it to work, thanks once again for your input, kind of new here and this site is a great help...... Gord
Post new topic    Yesterday's Tractors Forum Index -> Fordson All times are GMT - 8 Hours
