630 case
brian stanek
PostPosted: Thu Mar 08, 2018 3:25 pm    Post subject: 630 case Reply to specific post Reply with quote
has anyone used reman clutch and pressure plate? just wandering if it is a good way to go versus new. there is quite a difference in price.
1370rod
PostPosted: Fri Mar 09, 2018 5:08 am    Post subject: Re: 630 case Reply to specific post Reply with quote
We have used Reman for the past 30+ years and have had very good luck. Rod.
longcases
PostPosted: Fri Mar 09, 2018 6:25 am    Post subject: Re: 630 case Reply to specific post Reply with quote
If your tractor is diesel I would not use a reman pressure plate. The square hole in the pressure plate cover wears and when you push in the clutch it will rattle like the throwout bearing is bad but its the pressure plate floater that is rattling.
L.Fure
PostPosted: Fri Mar 09, 2018 6:29 am    Post subject: Re: 630 case Reply to specific post Reply with quote
longcases,
Does the rattle in the pressure plate lead into something worse, causing premature clutch failure?
gusbratz
PostPosted: Fri Mar 09, 2018 7:37 am    Post subject: Re: 630 case Reply to specific post Reply with quote
[quote="L.Fure"](quoted from post at 07:29:44 03/09/1Cool
longcases,
Does the rattle in the pressure plate lead into something worse, causing premature clutch failure?[/quote]
I am also curious. I am not sure what square hole you are talking about.
brian stanek
PostPosted: Fri Mar 09, 2018 12:12 pm    Post subject: Re: 630 case Reply to specific post Reply with quote
gusbratz wrote:
(quoted from post at 16:37:04 03/09/1Cool
longcases,
no the engine is the 188 gas however I am curious as to what it may do if there is a weakness in the clutch. all state parts has a woven clutch disc for my tractor however mine mite be the 4 pad any recomendatios either way? thanks
longcases
PostPosted: Fri Mar 09, 2018 3:43 pm    Post subject: Re: 630 case Reply to specific post Reply with quote
There are 3 driving lugs that come thru the cover with the adjustment screws for the fingers. On a diesel they get wallerd out and rattle when you push in the clutch. Only affects diesel not gas.
