Oil leak on 206 engines any ideas?
JOCCO
PostPosted: Thu Mar 08, 2018 5:50 pm    Post subject: Oil leak on 206 engines any ideas? Reply to specific post Reply with quote
A 206 jet star/445 type engine. Leaking between the cylinder blocks (where they bolt on to the crankcase) but having trouble finding it. Any ideas thanks
matthies
PostPosted: Thu Mar 08, 2018 6:09 pm    Post subject: Re: Oil leak on 206 engines any ideas? Reply to specific post Reply with quote
Might look on the generator side, the oil pipe that goes up to the valves, the rubber bushing that seals the pipe might have cracked or misaligned and allows oil to follow the pipe down to between the cylinders. Good luck.
T.R.K.
PostPosted: Thu Mar 08, 2018 6:14 pm    Post subject: Re: Oil leak on 206 engines any ideas? Reply to specific post Reply with quote
Is the leak on the right side near the oil tube?
It could also be one of the block gaskets.
I guess it could also be the gasket between the stud torque plate and one of the heads, and just run down and out from between the blocks.
FYI: the left side block bolts are in pockets just above the camshaft.
Ill John
PostPosted: Fri Mar 09, 2018 5:37 pm    Post subject: Re: Oil leak on 206 engines any ideas? Reply to specific post Reply with quote
I'm guessing it's the oil tube on the left side of the engine
Post new topic    Yesterday's Tractors Forum Index -> Minneapolis Moline All times are GMT - 8 Hours
