White 598 Plow
Willow Lane
PostPosted: Thu Apr 19, 2018 8:29 am    Post subject: White 598 Plow Reply to specific post Reply with quote
Greetings all, I'm a frequent reader but have only posted on here a couple of times. Anyway, I'm going tomorrow to look at a White 598 plow and would appreciate any comments.
Also, the parts book shows a "subsoiler attachment" and I was wondering if anyone has any experience with this. I assume that you remove the bottom and put the shank and point on, but I don't really know, so any comments on this would be welcomed also.
JMS/.MN
PostPosted: Thu Apr 19, 2018 10:12 am    Post subject: Re: White 598 Plow Reply to specific post Reply with quote
I"ve had Melroe plows with AC bottoms, 720 IH, and the White 588 or 598, all resets. By far, the White lays the best furrow over. 720 reset would often hang up on corn stalks when re-entering the ground. If both plows were in the same field I could tell which one plowed where. Repairs were simpler as well.
J. Schwiebert
PostPosted: Thu Apr 19, 2018 12:30 pm    Post subject: Re: White 598 Plow Reply to specific post Reply with quote
When I worked for a dealer we sold a fair number of those sub soil attachment. If you add a couple of those needless to say they work good, BUT the plow will also pull harder.
JD Seller
PostPosted: Thu Apr 19, 2018 3:23 pm    Post subject: Re: White 598 Plow Reply to specific post Reply with quote
That White 598 plow is one of the best ever made in my opinion. While I like JD stuff the White/Oliver plow was just hard to beat.
flying belgian
PostPosted: Thu Apr 19, 2018 3:33 pm    Post subject: Re: White 598 Plow Reply to specific post Reply with quote
You just are not going to find a better plow than a White. Pull easy and do a good job. I have a 2800 JD and I could drag my house through the field easier then pull that thing. I do like the vari-width though.
Princeton Bill
PostPosted: Thu Apr 19, 2018 5:15 pm    Post subject: Re: White 598 Plow Reply to specific post Reply with quote
The subsoiler is a shank that fits in a bracket behind the bottom. You don?t take the bottom off. The shank extends below the furrow as you are plowing. It helps break up the hard pan.
Mn Dave
PostPosted: Thu Apr 19, 2018 5:36 pm    Post subject: Re: White 598 Plow Reply to specific post Reply with quote
CVPost-Willow Lane wrote:
(quoted from post at 09:29:52 04/19/1Cool Greetings all, I'm a frequent reader but have only posted on here a couple of times. Anyway, I'm going tomorrow to look at a White 598 plow and would appreciate any comments.
Make sure you check all the pivot points, as these wear they cause the bottoms to not run true.
