MF 43 moldboard plow shares
dlinmi
PostPosted: Tue Apr 24, 2018 1:57 pm    Post subject: MF 43 moldboard plow shares Reply to specific post Reply with quote
I can't find a source for replacement shares. Tractor supply 16" share only matched 2 of the 3 holes. John Deere had a match at a sister store but only two points and I need 3, he said " if he had to order they come in bundles of 6 ". Agri Supply couldn't match and I can't find anywhere else. OEM part # 475135M1, and John Deere equivalent PMMF16-3. It's a 16" 3 bolt share. Any advice on removing mounting bolts on shares? Hit with impact and head spun in share. Got one off so far by angle grinding the flush mount head off, long process. Can't access nut side on two bolts because nut recesses into mounting bracket !! Thanks for any input/advice
Plowman
PostPosted: Tue Apr 24, 2018 4:53 pm    Post subject: Re: MF 43 moldboard plow shares Reply to specific post Reply with quote
Hi I might have some shares for you. Thanks Steve 419-618-0017
mijohn
PostPosted: Tue Apr 24, 2018 5:37 pm    Post subject: Re: MF 43 moldboard plow shares Reply to specific post Reply with quote
See if you can find someone close by to you that has an IH plow with 3 bolt shares. Had some one tell me that some IH and Massy plow used the same shares. If you can't find one, Wiese Industries has them listed.
SVcummins
PostPosted: Wed Apr 25, 2018 9:53 am    Post subject: Re: MF 43 moldboard plow shares Reply to specific post Reply with quote
If the nut won?t come I split it with a cutoff wheel in a
die grinder or angle grinder even if you can only cut
one corner of the nut off then you can smack it with
a cold chisel and big hammer and the nut will come
off if I still won?t take big punch and drive the bolt
through the nut
Dave Sherburne, NY
PostPosted: Wed Apr 25, 2018 11:09 am    Post subject: Re: MF 43 moldboard plow shares Reply to specific post Reply with quote
When you put the new ones on, put enough nuts on each bolt to cover the extra threads. They will be a lot easier to change next time.
RGMartin
PostPosted: Wed Apr 25, 2018 12:33 pm    Post subject: Re: MF 43 moldboard plow shares Reply to specific post Reply with quote
The frogs from a later 4 bolt plow will bolt on if you can find some used one. If this is for a toy plow(IE last set of shares it will ever get), probably more cost and effort than it is worth.
The other easy and obvious option is to put extra holes in a readily available share. Drill oversize holes and weld the bolts into the hole. I am a sucker for any shares that I can pick up at an auction that are dirt cheap. Not an ideal thing to do on a quick mid season change, but great way to save $100 on a snowy pre-season tune up.
300guy
PostPosted: Wed Apr 25, 2018 6:47 pm    Post subject: Re: MF 43 moldboard plow shares Reply to specific post Reply with quote
Always use anti-sieze on plow parts that are subjected to dirt, water and rust! They come off very easy years later.
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley All times are GMT - 8 Hours
