problem with Stieger Bearcat not starting
MartinKD
PostPosted: Thu May 17, 2018 12:36 am    Post subject: problem with Stieger Bearcat not starting Reply to specific post Reply with quote
It started fine at first, started moving around the yard to the fuel tanks, it started sputtering, coughing, struggling for fuel ( I think ) and then died.
Last spring the solenoid on the rear of the fuel pump had a loose post. It isn't loose this spring and it is acting like it has no fuel.
I used the drain on the bottom of the fuel filter and tried starting - no luck
I have a Caterpillar 3306 engine and wish to know what is the super proper way to bleed the fuel line or confirm that the fuel line is not the problem.
thanks
Martin
Bob
PostPosted: Fri May 18, 2018 6:49 am    Post subject: Re: problem with Stieger Bearcat not starting Reply to specific post Reply with quote
You might try asking in the "Hauling" and "Crawlers" sections of this site, as well.
Someone there may be more familiar with a CAT 3306 Diesel than the followers of this section, IMHO.
Post new topic    Yesterday's Tractors Forum Index -> Lesser Known Classics All times are GMT - 8 Hours
