TO35 Hydraulic lift troubleshooting
Goto page Previous  1, 2
mikeroche56
PostPosted: Thu Jun 21, 2018 5:16 pm    Post subject: Re: TO35 Hydraulic lift troubleshooting Reply to specific post Reply with quote
Oh, and my s/n is later 173xxx and i got the higher pressure relief valve.
John Deere D
PostPosted: Thu Jun 21, 2018 10:49 pm    Post subject: Re: TO35 Hydraulic lift troubleshooting Reply to specific post Reply with quote
When I was in the same boat as you are......a first rate re-build kit with everything including the ex-mother in-laws Dentures was from $188.00>$206.00.
Now pumps are available from $188.00 > $250.00
Installed a NEW pump, with 40 hrs. running time...(15-40 Oil)....pump is running fine:
I shall look into rebuilding the original, as I have neighbours with problematic Hydraulic PSI.
Bob.....MF FE 35 X
Steve@Advance
PostPosted: Fri Jun 22, 2018 10:30 am    Post subject: Re: TO35 Hydraulic lift troubleshooting Reply to specific post Reply with quote
I would take the splashing around the pump to indicate bad valves.
A very common problem.
mikeroche56
PostPosted: Sat Jun 23, 2018 6:17 am    Post subject: Re: TO35 Hydraulic lift troubleshooting Reply to specific post Reply with quote
Thanks for the help everyone. I ordered a pump. I'll report back how I make out. Mike
John Deere D
PostPosted: Sat Jun 23, 2018 7:15 am    Post subject: Re: TO35 Hydraulic lift troubleshooting Reply to specific post Reply with quote
How is the Back Lash on the Rear Drive Coupling?
I had to replace this coupling when the New Pump was Installed:
Bob..Owner Operator MF FE 35 X and other colored Tractors:
mikeroche56
PostPosted: Sat Jun 23, 2018 1:00 pm    Post subject: Re: TO35 Hydraulic lift troubleshooting Reply to specific post Reply with quote
Good tips, thanks Bob!
mikeroche56
PostPosted: Sun Jul 01, 2018 7:24 am    Post subject: Re: TO35 Hydraulic lift troubleshooting Reply to specific post Reply with quote
Hey Bob I received my pump this week and tried to install it for a little while last night. Is there any trick to shoe-horning the new pump into an older to35? Do you need to install the collar with the cotter pin on the forward pump shaft before you slide it down in or should you install it after? Do you tip the front in first or the back in first? Do you need to take the pressure relief valve or the control lever off before sliding the pump in? Any other advice?? Thanks!!
John Deere D
PostPosted: Sun Jul 01, 2018 2:28 pm    Post subject: Re: TO35 Hydraulic lift troubleshooting Reply to specific post Reply with quote
Good day Mikeroche56:
When I installed the NEW HYDRAULIC PUMP in my MF 35, I had to SPLIT / REMOVE the Transmission from the Diff. Housing,(SEE PICTURE) as I had a leaking GASKET between the AFT of the Transmission and the Diff. Housing to replace.
I installed the HYD.PUMP into the Diff. Housing (Installed the TWO LOCATING DOWELS)with the Forward drive coupling attached to the HYDRAULIC PUMP with the cotter pin.
Then installed several Line-up Pins / Bolts to align the Transmission with the Diff. Housing, and checked that the OUT PUT SHAFT of the TRANMISSION would align with the COUPLING drive on the HYD. PUMP.
With a helper we rolled the front half of the Tractor AFT, checked to verify that everything lined up properly.
We then rolled the front half of the Tractor / Transmission forward, Installed a NEW GASKET, adhesive and matted the Transmission to the Diff. Housing. Secured all bolts between the Transmission and the Diff. Housing.
The INPUT COUPLING drive of the HYDRAULIC PUMP did NOT align with the drive splines of the Transmission. We engaged the drive GEAR on the PTO SHAFT forwards, engaging the PYO drive to the HYDRAULIC PUMP, then turned the PTO SHAFT. The result that the HYDRAULIC PUMP DRVIE COUPLING aligned properly with the out put drive of the Transmission.
I have read in "YT" posts that YES it is possible to install the HYDRAULIC PUMP with out splitting the Transmission from the Diff. Housing on some Massey Models.
I have read in "YT" posts there are individual whom did not check all dimensions of the new PUMP against the OLD faulty pump, only to find the splines were DIFFERENT, as well as the width of the NEW PUMP was to wide to fit between the TWO mounting / securing Dowels.
If I had to change out a PUMP with out splitting the transmission from the DIFF. Housing, I would remove what ever it takes to do the installation "short of NOT dismantling the PUMP HOUSING."
Bob..
mikeroche56
PostPosted: Sun Jul 01, 2018 3:25 pm    Post subject: Re: TO35 Hydraulic lift troubleshooting Reply to specific post Reply with quote
Thanks, Bob. The pump width and the splines seem ok, i'll give it another go...
Mike
John Deere D
PostPosted: Sun Jul 01, 2018 5:53 pm    Post subject: Re: TO35 Hydraulic lift troubleshooting Reply to specific post Reply with quote
Be sure the RANGE SELECTOR is in "H"....allows for more room to install the HYD.PUMP.
Bob...
mikeroche56
PostPosted: Fri Jul 06, 2018 6:42 pm    Post subject: Re: TO35 Hydraulic lift troubleshooting Reply to specific post Reply with quote
Thanks everyone for the help. I got the new pump installed and it works great! Will make brush hogging a lot easier. I ended up removing the pump filter and control lever to make it easier to jockey around in the case and not worry about bending anything. Bad news is that I decided to replace the PTO bearing and oil seal while I had the shaft out and sure enough I scratched the shaft with the bearing c clip and now it leaks a little. Think I may need a speedi sleeve to repair. I tried polishing out the scratches, maybe the shaft is undersized slightly. Anybody have luck using speedi sleeves on to35 pto shafts? Thanks again! Mike
John Deere D
PostPosted: Fri Jul 06, 2018 9:20 pm    Post subject: Re: TO35 Hydraulic lift troubleshooting Reply to specific post Reply with quote
Thanks for posting back ......always great to hear a success story.
Bob....
257 Roberts
PostPosted: Wed Aug 01, 2018 5:11 am    Post subject: Re: TO35 Hydraulic lift troubleshooting Reply to specific post Reply with quote
I would tackle that steady stream from the cylinder first, that could be the source of all your woes. Your tractor has the 3" piston and cylinder, right? Did you say that the cylinder, piston, and rings are all new?
Page 2 of 2
