hardener in rustoleum primer?
William Fissell
PostPosted: Sun Jul 08, 2018 2:28 pm    Post subject: hardener in rustoleum primer? Reply to specific post Reply with quote
Hi,
I am going to paint my TO-35 with rustoleum - I liked the results ptfarmer achieved on his 135.
I was going to use rustoleum primer as there will be rust in the castings no matter what. I was going to drench it in Dawn, rinse, dry, scrub wiht naptha, and then apply picklex or phosx or simialr rust converter, then paint with rusty metal primer from rustoleum.
I will add hardener to the finish enamel, but should I ad it to the primer as well?
thanks in advance.
Bill
504
PostPosted: Sun Jul 08, 2018 4:42 pm    Post subject: Re: hardener in rustoleum primer? Reply to specific post Reply with quote
no
Stephen Newell
PostPosted: Sun Jul 08, 2018 6:10 pm    Post subject: Re: hardener in rustoleum primer? Reply to specific post Reply with quote
Don't add hardener to the primer unless you don't plan on sanding between coats. Primer is made soft to make it easy to sand and the hardener would counteract that.
ptfarmer
PostPosted: Sun Jul 08, 2018 9:44 pm    Post subject: Re: hardener in rustoleum primer? Reply to specific post Reply with quote
As the other have said no hardener in the primer. For the color with the hardener you need to thin the paint just a little bit with enamel reducer as the hardener works better with the enamel reducer.
William Fissell
PostPosted: Mon Jul 09, 2018 11:56 am    Post subject: Re: hardener in rustoleum primer? Reply to specific post Reply with quote
ptfarmer,
which reducer did you use with the rustoleum? and can you tell me proportions?
thanks
Bill
Stephen Newell
PostPosted: Tue Jul 10, 2018 3:09 am    Post subject: Re: hardener in rustoleum primer? Reply to specific post Reply with quote
With any oil based enamel you thin it as little as you can to make it work and only if it needs it. Try not thinning it at all first. Spraying it the paint should appear like it's going to orange peal while you are applying it. It's slow drying so it will flow together. Try it on something scrap first to see. If you thin oil based enamel too much it will make it take longer to dry and often screws up the sheen. It also makes it more prone to get runs in it. If the paint needs thinner just use a couple of tablespoons per quart first and it takes a lot of stirring to get it to mix.
ptfarmer
PostPosted: Tue Jul 10, 2018 7:28 am    Post subject: Re: hardener in rustoleum primer? Reply to specific post Reply with quote
CVPost-William Fissell wrote:
(quoted from post at 12:56:33 07/09/1Cool ptfarmer,
thanks
Bill
They have a slow, medium, and fast enamel reducers which depends on what the temperature is when you are spraying (hotter/slower, colder/faster). I get my enamel reducer from a automotive paint store, and you don't have to use very much reducer. Its usually cheaper to get a gallon of reducer instead of a quart. If its going to get close to 100 degrees even the slow reducer will start to dry too fast, if its over 100 degrees don't paint.
ptfarmer
PostPosted: Tue Jul 10, 2018 7:47 am    Post subject: Re: hardener in rustoleum primer? Reply to specific post Reply with quote
Rust-o-leum paint from Home Depot for $9 a quart, and little automotive enamel reducer with the hardener.
For the MF flint metallic gray I mixed a quart each of rust-o-leum smoke gray, aluminum, and gloss black. For the MF silver a quart of smoke gray, and a quart of aluminum. For the red I used rust-o-leum Sunrise red (even though its not the correct color), the gray, and silver aren't correct, but its close enough for me.
William Fissell
PostPosted: Tue Jul 10, 2018 11:05 am    Post subject: Re: hardener in rustoleum primer? Reply to specific post Reply with quote
Thank you. Theres a lot of enamel reducers out there and I had/have no idea what will work. Ill post some pics when I am (finally) done. Hows the fading on the sunrise red?
ptfarmer
PostPosted: Tue Jul 10, 2018 11:27 am    Post subject: Re: hardener in rustoleum primer? Reply to specific post Reply with quote
No fading on the red yet after almost 2 years, whenever its not used its in the barn, or under a good shade tree for a few hours. It's only out in the sun when its working, its a pain to paint a tractor so anything I can do to make the paint last longer the better.
Post new topic    Yesterday's Tractors Forum Index -> Paint and Bodywork All times are GMT - 8 Hours
