Where To Buy The Best IH Paint ( Red)
Garry L. Ireton
PostPosted: Thu Jan 18, 2007 8:53 am    Post subject: Where To Buy The Best IH Paint ( Red) Reply to specific post Reply with quote
As I know I each person has he own selection of paint dealers All is helpful.
Which paint is the best for a complete restore job
I want to get the deepest and hardest shine possible , I have heard before putting on your red to apply a coat of white for the base coat to get a more richer or Brighter looking red paint job is this true.
Any and all feedback will be helpful.
Thanks To All
glennster
PostPosted: Thu Jan 18, 2007 10:49 am    Post subject: Re: Where To Buy The Best IH Paint ( Red) Reply to specific post Reply with quote
whew, thats a loaded question, so i will just generalize a wee bit. any of your major brands of automotive paintwill give you good results IF you follow their proceedures and dont mix, match or experiment. you can use the less expensive lines, ie napa martin senyour stuff or go all the way up to sikkens or glasurit high line stuff. your budget and your skill will help determine what product you use. as far as painting white as a base coat, you are better off using a different color primer instead. if you want a reallly deep shine, go base coat clear coat, and use a glamour clear coat instead of a typical production clear. it has very little orange peel and produces a high gloss finish.
CNKS
PostPosted: Thu Jan 18, 2007 6:29 pm    Post subject: Re: Where To Buy The Best IH Paint ( Red) Reply to specific post Reply with quote
Which IH red? There were at least four. Only two that I am positive can be mixed is IH 50 (up to 1949) and 2150 (1961--up). Not sure the other two can be mixed, 1102 (1949-1958) and 201 (1958-1961), you might check with your local paint supplier -- give him the codes. The premixed versions are anyone's guess, even that sold by Case-IH. IH 50 crosses to PPG 70019/DuPont 7410, 2150 to PPG 71310/DuPont 96766; Martin Senour and other major brands can be mixed too. Most people, unless absolute purists, use the 2150 versions. Good results can be had with the "economical" PPG Omni/DuPont Nason lines. The price goes up from there. If you do not have the proper protective equipment it is best to stick with the acylic enamel versions without hardener. If you are willing to invest in supplied air, acrylic urethane is better. PPG prices for acrylic urethane with hardener is about $130/gallon, price goes up from there. Expect to pay another $150 for the proper primers, reducers, ect. Or, you can buy 2150 from your Case-IH dealer for less than $100 including primer and get a decent job. NONE of the above paints will exactly match the paint that came on your tractor. Base-clear will give a better shine, but is not necessary. As to the white, I think that is baloney. Use the primers recommended by the topcoat manufacturer. The color of the primer makes little difference. I like a contrasting primer because I can see if I have good coverage. But, a similar color primer will make the inevitable chips, etc, harder to see.
Post new topic    Yesterday's Tractors Forum Index -> Paint and Bodywork All times are GMT - 8 Hours
