9170 overheating
kb88
PostPosted: Thu Sep 20, 2018 4:24 pm    Post subject: 9170 overheating Reply to specific post Reply with quote
I have a deutz 9170 that's getting warm.
Fins are all clean and the fan looks
good. Just wondering if there's
something else to look for.
Dieseltech
PostPosted: Thu Sep 20, 2018 4:34 pm    Post subject: Re: 9170 overheating Reply to specific post Reply with quote
Injection pump governor seals broken, and max full load fuel setting increased higher than it should be?
kb88
PostPosted: Thu Sep 20, 2018 5:09 pm    Post subject: Re: 9170 overheating Reply to specific post Reply with quote
I thought that was the problem so I turned it down. Still is getting hot. If I run it all day the hydraulic will get warm too. I'm thinking it's a fan issue
DrAllis
PostPosted: Fri Sep 21, 2018 6:29 am    Post subject: Re: 9170 overheating Reply to specific post Reply with quote
The cooling fan is a fluid drive. There is a control valve on the engine that throttles oil to the fluid drive speeding up or slowing down the fan as needed. I believe that is where your problem is.
kb88
PostPosted: Fri Sep 21, 2018 6:54 am    Post subject: Re: 9170 overheating Reply to specific post Reply with quote
I took the washer out to make the fan
run all the time. Is it possible that it
is plugged or something?
DrAllis
PostPosted: Fri Sep 21, 2018 8:41 am    Post subject: Re: 9170 overheating Reply to specific post Reply with quote
Been too many years ago for me to remember.
sherman
PostPosted: Mon Oct 08, 2018 7:59 pm    Post subject: Re: 9170 overheating Reply to specific post Reply with quote
You need to check your injection pump timing and set your valve lash. very critical on a deutz, also make sure your oil coolers are not dirty/ plugged and hoses are clear and not kinked. take a digital laser temp guage and check each cylinder /head when it gets hot. I bet you find one that's a lot hotter, that's your culprit.
good luck
