D17 allis
Goto page 1, 2  Next
Jona
PostPosted: Fri Oct 05, 2018 4:31 pm    Post subject: D17 allis Reply to specific post Reply with quote
I just purchased a D 17 and I'm wondering why there's only one hydraulic outlet out back and can I change that to two
And where would that control lever for that outlet be?
I want to use it on a snowblower chute to rotate it .
And what would be The best way to solve this problem ?
JMS/.MN
PostPosted: Fri Oct 05, 2018 4:36 pm    Post subject: Re: D17 allis Reply to specific post Reply with quote
D17 had a limited hyd capability. Simplest to add a separate hyd system with a front mount pump. The front of the crankshaft pulley should have 4 drilled/tapped bores where you can attach the pump drive to.
Jona
PostPosted: Fri Oct 05, 2018 4:42 pm    Post subject: Re: D17 allis Reply to specific post Reply with quote
It does have a front end AC loader with front pump how can I fix that .
Jona
PostPosted: Fri Oct 05, 2018 5:19 pm    Post subject: Re: D17 allis Reply to specific post Reply with quote
Where is the control for that single outlet in back
Aaron SEIA
PostPosted: Fri Oct 05, 2018 5:54 pm    Post subject: Re: D17 allis Reply to specific post Reply with quote
Back lever in the left side of the steering wheel runs the single remote. If you have a front pump and valve block, just add another valve.
AaronSEIA
DrAllis
PostPosted: Fri Oct 05, 2018 7:00 pm    Post subject: Re: D17 allis Reply to specific post Reply with quote
I guess if it was my tractor, I'd add an OPEN CENTER single spool valve with "Power Beyond" capability plumbed in before the loaders dual spool valves. This would be live whenever the engine runs. I'd think about locating to the left of the seat for easy access to connect your blower chute cylinders hoses. You could also plumb a single spool valve thru the single outlet you already have on the rear of the tractor, but that would be very second rate compared to the power beyond valve configuration that would be "live" whenever the engine runs.
Jona
PostPosted: Fri Oct 05, 2018 7:14 pm    Post subject: Re: D17 allis Reply to specific post Reply with quote
I am the 83 year old man.can someone send some pics. On all of this?tomorow I will send pics. Of tractor
Thanks much for allresponds need all the helpi can get. This is mY last big joy.
Jack
Traditional Farmer
PostPosted: Sat Oct 06, 2018 12:57 am    Post subject: Re: D17 allis Reply to specific post Reply with quote
You can get a Prince or other valve from Surplus Center that has the power beyond feature so you can run it in line with your loader valve as Dr Allis described.I'd get a double valve as you never know you make need two at some time in the future.
Jona
PostPosted: Sat Oct 06, 2018 4:18 am    Post subject: Re: D17 allis Reply to specific post Reply with quote
Hears a pic. Can I tie on to front pump to a control valve for the back?
Yet what controls back outlet can I tie another on that?
DrAllis
PostPosted: Sat Oct 06, 2018 6:20 am    Post subject: Re: D17 allis Reply to specific post Reply with quote
To operate your lift arms AND provide oil flow to that single outlet, you use the long lever on the left side of the steering wheel. UP will raise the arms. MIDway will hold the arms. DOWN below horizontal will lower the arms. The foot clutch must be released for this system to work. It is a high pressure (3700 psi) system and made for high pressure cylinders. If you want a good system, tie into the loaders hydraulic system like I described in my earlier post. It will require fabrication to mount a power beyond type valve to the left of the seat and make hoses to plumb everything. I'd be glad to build it for you, but I'll bet we're hundreds of miles apart.
DrAllis
PostPosted: Sat Oct 06, 2018 6:27 am    Post subject: Re: D17 allis Reply to specific post Reply with quote
I see someone has painted up your tractor to make it look like a D-17 series 3 model. It isn't that new. It has an oil bath air cleaner, so it is a 1957 thru 1961 version as I see it here. The true series 3 models were 1962 and 63 and had dry air cleaners and an oval muffler and headlites on the fenders. Mufflers and headlites often got changed to the newer style, but the oil bath air cleaner is the dead giveaway on age.
Jona
PostPosted: Sat Oct 06, 2018 10:03 am    Post subject: Re: D17 allis Reply to specific post Reply with quote
I know it's a Series 2 with the wrong decal the serial number is 40337 does this tell you anything that I don't know I though it was a early 1962
Help.
Jack
Jona
PostPosted: Sat Oct 06, 2018 11:08 am    Post subject: Re: D17 allis Reply to specific post Reply with quote
D allis- if I get longer hoses for the snowblower and tie them into the loader outlets will the loader
stay up on its own for at least an hour or two ?
old
PostPosted: Sat Oct 06, 2018 1:26 pm    Post subject: Re: D17 allis Reply to specific post Reply with quote
If you install quick connects to the hoses in theory the loader should stay up for days if not week but one never knows. Might be better and easier to just add another valve to the loader set up and they you keep the loader working plus the blower
DrAllis
PostPosted: Sat Oct 06, 2018 1:33 pm    Post subject: Re: D17 allis Reply to specific post Reply with quote
Longer hoses to the loader would be a way of accomplishing your goal, altho not as handy. Consider tapping into the bucket lines instead of the boom. If you had a shut-off valves on each of the 4 hoses involved, you would never have to unhook anything. Just turn off two shut-offs and turn on two shut-offs with all four hoses always connected ready to work.
Goto page 1, 2  Next
Page 1 of 2
