1086 Won't Raise Load On Remotes
Goto page 1, 2, 3  Next
addisonfarms
PostPosted: Sun Oct 07, 2018 4:09 am    Post subject: 1086 Won't Raise Load On Remotes Reply to specific post Reply with quote
My 1086, s/n 60522 with open-center hydraulics, is having an issue with raising my disc when hooked to the remote. Here is what has been done/checked so far:
- Fluid level checked and topped off
- Recent hydraulic filter change (roughly 10 hours of use since change)
- Worked when using my old haybine to raise the cutterbar
- Will extend the cylinder when it is detached from the disc (no load)
- Just to rule out issues, replaced the hose ends on the disc with new ones
- Have tried both of the remotes on the back of the tractor with same results
- It will extend when hooked to disc until the point that the wheels make contact with ground and then that's it, will lift wheels quick and just fine.
- Have tried it with the 3-point lever in various positions. When in the range where it controls the draft response the remotes respond slower/faster for the little bit of movement they actually do, which is the way it is designed.
- The levers seem to have a noticeable detent in the various positions as you would expect them to.
Kind of at a loss as to where to look next without jumping to the conclusion that its the pump. Are there some things I am missing in my troubleshooting? Outside of having the expensive IH Flo Rater gauge setup is there a working-man's way of testing the pressure? Could this problem be related to a check valve issue? I believe this model has a check valve right beneath the cab that the lines coming from the remotes attach to ( at least that is going by the parts diagram, a box shaped device ).
Super B
PostPosted: Sun Oct 07, 2018 4:43 am    Post subject: Re: 1086 Won't Raise Load On Remotes Reply to specific post Reply with quote
There is an o-ring on the output of the hyd pump that could be blown, you need to drain the fluid and pull the pump if o-ring is blown when replacing it they make a plastic retaining ring to go around the o-ring to even pressure, kind of a job but a cheap fix, if that is it. if it is the o-ring your 3 point won't lift with a load on it or will go up then drop.
caterpillar guy
PostPosted: Sun Oct 07, 2018 5:37 am    Post subject: Re: 1086 Won't Raise Load On Remotes Reply to specific post Reply with quote
You can put a pressure gage in the remotes, and this will give you a reading of pressure or the lack of depending on the case.
Janicholson
PostPosted: Sun Oct 07, 2018 7:02 am    Post subject: Re: 1086 Won't Raise Load On Remotes Reply to specific post Reply with quote
In some cases, putting 5 gallons of hytran in the tractor above full will disguise an Oring problem and hurts nothing. Cheap fix if it works. Jim
addisonfarms
PostPosted: Sun Oct 07, 2018 7:44 am    Post subject: Re: 1086 Won't Raise Load On Remotes Reply to specific post Reply with quote
Hate to ask a question such as this, but can I use any hydraulic pressure gauge as long as it is rated to say 3,000 psi or higher? Assume I would just get a fitting to put on end of the hose that I could screw this gauge into correct?
addisonfarms
PostPosted: Sun Oct 07, 2018 7:48 am    Post subject: Re: 1086 Won't Raise Load On Remotes Reply to specific post Reply with quote
Would it stand to reason that if I can lift and hold up a "heavy" load with the 3-point that this would rule out the blown o-ring?
addisonfarms
PostPosted: Sun Oct 07, 2018 7:53 am    Post subject: Re: 1086 Won't Raise Load On Remotes Reply to specific post Reply with quote
Would it stand to reason that if I CAN lift and hold-up a "heavy" load on the 3-point that it will rule out the blown o-ring possibility?
leroy in ne
PostPosted: Sun Oct 07, 2018 8:03 am    Post subject: Re: 1086 Won't Raise Load On Remotes Reply to specific post Reply with quote
This may seem a silly question, but have you tried another cylinder? reversing hoses at quick coupler? moving lever with nothing hooked to hydraulics and listening for engine to load when hyd is dead headed? possible cylinder seals on piston are blown, piston loose on shaft ect.
addisonfarms
PostPosted: Sun Oct 07, 2018 11:21 am    Post subject: Re: 1086 Won't Raise Load On Remotes Reply to specific post Reply with quote
Not silly. No I haven't tried a different cylinder. Did reverse hoses and did hook hoses to the other remote outlet with the same results. Also removed cylinder from the implement and actuated it through its full motion both ways with no problem. Can't say I let it deadhead at the end of the stroke but so far every things I've done has not generated much of "load" sound on the engine.
addisonfarms
PostPosted: Sun Oct 07, 2018 4:03 pm    Post subject: Re: 1086 Won't Raise Load On Remotes Reply to specific post Reply with quote
I did try moving controls with nothing hooked up and yes you can hear engine lugging a little, not like its going to choke down but it does change. Would that be as expected on a normal system?
Janicholson
PostPosted: Sun Oct 07, 2018 4:09 pm    Post subject: Re: 1086 Won't Raise Load On Remotes Reply to specific post Reply with quote
If the cylinder is bad, the piston packing might be leaking fluid from one end to the other. Can you get near the haybine to see if it still lifts it? If so, My money is no a bad cylinder piston seal. Jim
Super B
PostPosted: Sun Oct 07, 2018 4:41 pm    Post subject: Re: 1086 Won't Raise Load On Remotes Reply to specific post Reply with quote
if you can lift and hold a heavy load on 3 pt you don't have a blown o-ring on the pump.
Super B
PostPosted: Sun Oct 07, 2018 4:47 pm    Post subject: Re: 1086 Won't Raise Load On Remotes Reply to specific post Reply with quote
If you can hold a load on the 3 pt it would also rule out a bad pump and let you know it is your remote outlets or a bad remote cylinder.
leroy in ne
PostPosted: Sun Oct 07, 2018 5:08 pm    Post subject: Re: 1086 Won't Raise Load On Remotes Reply to specific post Reply with quote
building pressure would require power that is why it loaded engine slightly, that would also check if you had a mechanical problem in pump drive my take not being there is you have more info to work with until you dead head into a pressure gage. also some people judge by the way hoses jump when pressure spikes as in end of stroke or dead heading.
addisonfarms
PostPosted: Sun Oct 07, 2018 5:18 pm    Post subject: Re: 1086 Won't Raise Load On Remotes Reply to specific post Reply with quote
Ok. Will do that in the morning. Would you think a 4-bottom turn plow would be sufficient of a load?
Page 1 of 3
