Ford 3000 Electrical malfunction
FordownerTodd
PostPosted: Mon Oct 08, 2018 12:51 pm    Post subject: Ford 3000 Electrical malfunction Reply to specific post Reply with quote
Anyone who may have an idea, please advise. I recently notice the red lights in the instrument panel were on on my Ford 3000 and the key was in the off position. Replaced the key switch, but still does it with the battery hooked up. Should I consider replacing the Generator first or where should I start? Is it best to switch to an alternator instead of the 12V Lucas Generator #22756?
I have inspected all the wires for a short and find nothing. The instrument panel fuel gauge and temperature gauge have not been working either for a few months, perhaps start with a new instrument panel? Thinking could it be one of these 2 items malfunctioning causing a short in the system? Totally puzzled and new to this tractor since purchasing just over a year ago. Confused
Bern
PostPosted: Mon Oct 08, 2018 1:25 pm    Post subject: Re: Ford 3000 Electrical malfunction Reply to specific post Reply with quote
My first guess is that your key switch is mis-wired. If you're sure it's OK, then it about has to be a short somewhere in the
harness, or else your light switch circuit (or similar) is back feeding into your gauge circuit somehow. If BOTH lights are
on, it's not the generator or regulator, and it's not the instrument cluster.
I wouldn't be surprised if it ends up being rodent damage on top of the fuel tank.
Another thought - are you sure the lights in question are not the illumination lights for the cluster, stuck in the wrong
holes?
sotxbill
PostPosted: Mon Oct 08, 2018 2:48 pm    Post subject: Re: Ford 3000 Electrical malfunction Reply to specific post Reply with quote
CVPost-Bern wrote:
(quoted from post at 16:25:29 10/08/1Cool My first guess is that your key switch is mis-wired. If you're sure it's OK, then it about has to be a short somewhere in the
holes?
bad/stuck vr regulator, along with a bad cluster ground will cause a back feed to the other light and the oil sending unit will complete the circuit to make both lights stay on as well???(grasping at straws here)
sunbeam
PostPosted: Mon Oct 08, 2018 5:07 pm    Post subject: Re: Ford 3000 Electrical malfunction Reply to specific post Reply with quote
I would look for an instrument panel ground voltage grounding out through the light bulbs.
TimInd
PostPosted: Mon Oct 08, 2018 6:16 pm    Post subject: Re: Ford 3000 Electrical malfunction Reply to specific post Reply with quote
Oh boy. Same old stuff. Those idiot lights will give you problems ad infinitum. I finally gave up, drilled two, 2" holes in the dash and added an oil pressure and volt meter to them courtesy of Auto Zone. Now I know what the Hell is going on. I also took out the bulbs in the idiot lights. I used an actual oil line from the block for the oil pressure gauge and patched in a wire to the circuit for the voltmeter gauge. The wire can be patched in anywhere along the charging circuit. If you want to keep it stock, then everything I said is inconsequential.
FordownerTodd
PostPosted: Tue Oct 09, 2018 4:38 am    Post subject: Re: Ford 3000 Electrical malfunction Reply to specific post Reply with quote
CVPost-Bern wrote:
(quoted from post at 14:25:29 10/08/1Cool My first guess is that your key switch is mis-wired. If you're sure it's OK, then it about has to be a short somewhere in the
holes?
Thanks Bern, You are absolutely correct it started out as what appeared to be mice that had built a nice nest on top of the gas tank, having had the instrument panel out several times now I thought I had looked the wiring harness over pretty good and found no damage.
I truly feel that I copied the key switch wiring correctly, and it is doing the very same thing that it did before I changed it.
I really don't think it is lights in the wrong holes, because the day I walked in the barn and found them on was prior to taking anything apart. Really no lights at all should have been illuminated. So I am leaning towards damaged wire(s) I am just going to have to get a little deeper into the wiring to find something. I think you are right it happened after the mice had set up home. Makes me really feel stupid not being able to put a finger on this. I will keep trying. Thanks again, Todd
Bern
PostPosted: Tue Oct 09, 2018 9:31 am    Post subject: Re: Ford 3000 Electrical malfunction Reply to specific post Reply with quote
JMOR
PostPosted: Tue Oct 09, 2018 12:04 pm    Post subject: Re: Ford 3000 Electrical malfunction Reply to specific post Reply with quote
Looking at the schematic, I would search for a path the allows voltage to be applied to the sender side of oil pressure and gen warning lamps (path should not be there with all shutdown). Disconnect wire normally connected to oil pressure switch and see if that wire has voltage on it. It should not.
sotxbill
PostPosted: Wed Oct 10, 2018 6:45 am    Post subject: Re: Ford 3000 Electrical malfunction Reply to specific post Reply with quote
Per a recent survey, 7 out of every 10 mice prefer a ford tractor for a nest.
JMOR
PostPosted: Wed Oct 10, 2018 6:51 am    Post subject: Re: Ford 3000 Electrical malfunction Reply to specific post Reply with quote
Seems as though the other 3 sorry b@$I@*&s prefer the wires on top of my 1992 Chevy 2500 gas tank! What is it? Do they like the smell of gas or what? Evil or Very Mad
FordownerTodd
PostPosted: Wed Oct 10, 2018 1:22 pm    Post subject: Re: Ford 3000 Electrical malfunction Reply to specific post Reply with quote
JMOR wrote:
(quoted from post at 07:51:47 10/10/1Cool
Seems as though the other 3 sorry b@$I@*&s prefer the wires on top of my 1992 Chevy 2500 gas tank! What is it? Do they like the smell of gas or what? Evil or Very Mad[/quote]
JMOR, Lol......that is a good one and probably a fairly accurate survey. Darn rodents have a great home with a tractor having so many open chambers to build nests in. Then when you have it parked near the chicken feed makes it convenient for the little destructive creatures!
I am gonna spend more time tracking wires for a short, but gonna try a new Voltage Reg this weekend! Thanks all! Todd
