Farmall 300 rear hydrualic lines
330 Standard
PostPosted: Tue Oct 09, 2018 10:59 am    Post subject: Farmall 300 rear hydrualic lines Reply to specific post Reply with quote
Anybody know of anyone who sells or repairs farmall hydraulic lines. I have a 300 that had a pinhole rust thru on the lines going to the rear fast hitch cylinder. I got it off and we welded up the worst pitted places but given as much trouble as it was to remove from under the dash I'd like to buy a new set or have the blocks re-tubed so I don't have to go thru pulling it off again in the future when another pitted place blows out. Thanks
fastfarmall
PostPosted: Tue Oct 09, 2018 11:52 am    Post subject: Re: Farmall 300 rear hydrualic lines Reply to specific post Reply with quote
So was that sitting with he valve cover off, that's what it looks like to me,I bought a tap and die set that was in the original plastic blow formed container, a little water got in there i had to use the[1/3 horse] wire brush on each piece to get the rust off!
2late4me
PostPosted: Wed Oct 10, 2018 5:45 am    Post subject: Re: Farmall 300 rear hydrualic lines Reply to specific post Reply with quote
I know it's not approved by the correct police but the tube is usually still good on the vertical part so I will cut the line and use a nut and ferule and run a hose to the rear.
charlieu
PostPosted: Wed Oct 10, 2018 3:43 pm    Post subject: Re: Farmall 300 rear hydrualic lines Reply to specific post Reply with quote
A number of years ago I needed the lower tube for my 350 Farmall, I went to a Hyd tube bender and had some made up. If the tube you need is the lower one. I can sell you what you need. The old tube can be heated for removal and the replacement is silver soldered in. Charlie U
