Ford 4000 3 cylinder gas 1965
Jkfarm
PostPosted: Thu Oct 11, 2018 12:33 pm    Post subject: Ford 4000 3 cylinder gas 1965 Reply to specific post Reply with quote
Hi I'm new I apologize if this shows up
twice. I would like some help on if I have
high and low beam lights 12v if I can plug
them in the harness or if I need additional
wiring. The switch I'm using is push, pull,
pull (C5NN11654A) withe the terminals
marked blank,A, H, R. Also looking to see
how to wire the fuel gauge. Thanks
Larry NCKS
PostPosted: Thu Oct 11, 2018 1:07 pm    Post subject: Re: Ford 4000 3 cylinder gas 1965 Reply to specific post Reply with quote
Welcome to the forum.
While I'm not certain I think you'd have to add wiring, change the switch, and change headlamp sockets to accommodate low/high beam headlights,
On an IH tractor or that vintage A, H, R would mean All, Headlights, and rear Red . . . I think. We'll see if others have better knowledge of your tractor than I do.
JMOR
PostPosted: Thu Oct 11, 2018 1:24 pm    Post subject: Re: Ford 4000 3 cylinder gas 1965 Reply to specific post Reply with quote
Larry NCKS wrote:
(quoted from post at 17:07:46 10/11/1Cool Welcome to the forum.
European version would have wiring for high and low beams and a switch with more positions and terminals.
Jkfarm
PostPosted: Thu Oct 11, 2018 1:29 pm    Post subject: Re: Ford 4000 3 cylinder gas 1965 Reply to specific post Reply with quote
Thanks for the quick response, the
headlights I purchased came with double
filament bulbs and 3 wires I thought they
were 2 wire 12v cause that what pictures
the sell had. Thanks
Destroked 450
PostPosted: Thu Oct 11, 2018 3:49 pm    Post subject: Re: Ford 4000 3 cylinder gas 1965 Reply to specific post Reply with quote
The high low beam european lights use a rotary three position switch, you also have to run another wire from the switch to the headlights, the standard US wiring harness only has one wire going to the front lights.
