Removal Of Rear Tire Mounted on 190XT
FarmerHR
PostPosted: Thu Oct 11, 2018 9:28 pm    Post subject: Removal Of Rear Tire Mounted on 190XT Reply to specific post Reply with quote
Need to remove the 18.4x34 eight ply tire mounted on an 190XT. The tire is very old and stiff and I think it may be the original tire. The bead is broken on both sides. Now I need to remove the tire from the rim.
I have put blocks of wood all around the inside and the front half of the tire to move the bead off the flat part of the rim. I have lowered the tractor so there is pressure on the bottom to push the tire up into the drop part of the rim on the bottom. I have been able to get about an eight inch section of the front bead past the outside of the rim at the top. It is really getting tough at this point to get more of the tire off. I would appreciate any help on how I should proceed. Also are there any lubricants that I should be using ? Would also like to hear any experiences you have had.
Thank you in advance for any help you can give me.
smileykeith
PostPosted: Fri Oct 12, 2018 1:33 am    Post subject: Re: Removal Of Rear Tire Mounted on 190XT Reply to specific post Reply with quote
If tire is junk a sawzall works great other wise i use dish soap for lub
IA Roy
PostPosted: Fri Oct 12, 2018 11:35 am    Post subject: Re: Removal Of Rear Tire Mounted on 190XT Reply to specific post Reply with quote
Look on YouTube. Probably many videos on how to remove rear tractor tire. Breaking beads is the hardest part. Pretty easy after that. Easier for someone to show you than for me to describe how.
shaun wallace
PostPosted: Fri Oct 12, 2018 4:44 pm    Post subject: Re: Removal Of Rear Tire Mounted on 190XT Reply to specific post Reply with quote
I take junk tires off with chainsaw. Cut about 2-3 inch from bead then usually bead will fall off. If not broke down use cutoff wheel to cut bead.
Hurst
PostPosted: Tue Oct 16, 2018 11:49 am    Post subject: Re: Removal Of Rear Tire Mounted on 190XT Reply to specific post Reply with quote
Do you have a bale spear for loader or 3pt? If so, I usually get the bead started over the rim where I can get the spear between the tire and rim ( ) and then put the tractor in reverse (so it pushes down on the spear and not pulling up) and slowly let it do the work. It should work just like a tire machine on a large scale. Also, did you pull the tube out yet? If you can get the tube out first, that will make sure it is not blocking the bead from dropping down into the drop area of the rim. It really should just come off as soon as the opposite end of the tire is in the drop section of the rim, just a matter of handling the weight and flexing the sidewalls to keep the tire coming off.
Hurst
Dick L
PostPosted: Wed Oct 17, 2018 2:03 pm    Post subject: Re: Removal Of Rear Tire Mounted on 190XT Reply to specific post Reply with quote
I just took one side off a few days ago to pull the tube out so it could be patched and videoed it. Some of it only. I thought I had posted but at 80 I might have thought I did and didn't. It is not a how to video by any means but how I did it.
Removed Inter Tube.
