Wisconsin VF4D VH4D parts ??
Glen in TX
PostPosted: Tue Jun 13, 2006 2:20 pm    Post subject: Wisconsin VF4D VH4D parts ?? Reply to specific post Reply with quote
I have a locked down parts engine Wisconsin VH4D with electric start and flywheel stator alternator. Will the VH4D flywheel work okay on the VF4D hand crank engine and will other parts interchange? Want to put electric start on the VF4D engine on a Lincoln welder. They look close to the same. Also have another parts engine V461D if anyone needs it for parts. Thanks.
senlim
PostPosted: Tue Jun 13, 2006 5:02 pm    Post subject: Re: Wisconsin VF4D VH4D parts ?? Reply to specific post Reply with quote
Many parts on VF4D and VH4D are interchangeable. The parts not interchangeable are crankshaft, camshaft, distributor or magneto. This is due to the different firing angles. The VH4D is and evenly spaced 180 deg between firing the VF4d is uneven with one spacing being only 90 deg and another being 120 deg. I think the big end bearings are different sizes as well so con rods would not be interchangeable. As to the flywheel I have no experience of the stator alternators on these engines.
Good luck
Senlim
Glen in TX
PostPosted: Tue Jun 13, 2006 6:03 pm    Post subject: Re: Wisconsin VF4D VH4D parts ?? Reply to specific post Reply with quote
Ok, Thanks. I knew there were odd and even fire ones but wasn't sure which ones anymore. Anyone know how hard to get flywheels off or trick for that too? Got the snake oil soaking on them and hoping they come off soon. Thanks.
senlim
PostPosted: Tue Jun 13, 2006 8:19 pm    Post subject: Re: Wisconsin VF4D VH4D parts ?? Reply to specific post Reply with quote
To remove Wisconsin flywheel:-
1 – loosen flywheel retaining nut several turns– do not use flywheel fins to prevent flywheel from turning during this operation.
2 – hold top of flywheel (fingers round fins) with one hand and lightly pull away from crankshaft (heel of hand on shroud) while striking the end of the crankshaft hard with a heavy deadblow hammer (official way), or as I used to do with a heavy steel hammer. Do this with feeling and confidence. Struck hard few flywheels need more than one good, heavy blow.
When replacing flywheel do not use oil on taper as this may lead to flywheel chatter and expensive damage.
Good luck
Senlim
Colorado Curt
PostPosted: Thu Jun 15, 2006 2:24 pm    Post subject: Re: Wisconsin VF4D VH4D parts ?? Reply to specific post Reply with quote
Has anyone out there actually removed a flywheel that way? I know that is what it says in the manual, but I have removed at least 5 of them and I have always had to tap holes in the flywheel and use a puller. I broke two pullers and had to use some heat on one of them.
senlim
PostPosted: Thu Jun 15, 2006 8:58 pm    Post subject: Re: Wisconsin VF4D VH4D parts ?? Reply to specific post Reply with quote
I used to work for Wisconsin dealer and have removed hundreds of flywheele this way - the only exception is the V461D and V465D they already have bolt holes for a puller plate in the flywheel boss.
As my service manger said "hit it like you mean to kill it" - a 4 lb hammer was all I used. Still have the hammer.
Yes it works
Senlim
Colorado Curt
PostPosted: Fri Jun 16, 2006 7:39 am    Post subject: Re: Wisconsin VF4D VH4D parts ?? Reply to specific post Reply with quote
Hitting it that hard will damage the bearings.
senlim
PostPosted: Fri Jun 16, 2006 3:46 pm    Post subject: Re: Wisconsin VF4D VH4D parts ?? Reply to specific post Reply with quote
never damaged any bearings
Glen in TX
PostPosted: Thu Jul 06, 2006 7:49 am    Post subject: Re: Wisconsin VF4D VH4D parts ?? Reply to specific post Reply with quote
Curt, Had to remove both of them and both were stuck hard and had to soak with Kroil and turn a brass bump cap for the crank and use the BFH (big sledge) more than a few hard bumps and flywheels finally came off. Was able to get behind the one prying some to help. I also tapped around on them with my air hammer using brass bump cap to help loosen them up. Still not easy thouugh. Thought I was going to have to drill and tap to pull them too. Took over a week soaking to get them off. Then had to degrease everything for assembly. They made bump caps like that for the cranks on B&S and it always helped bumping hard while prying to get flywheels off.
p100kman
PostPosted: Sat Dec 18, 2010 6:02 pm    Post subject: Re: Wisconsin VF4D VH4D parts ?? Reply to specific post Reply with quote
Glen in TX wrote:
(quoted from post at 15:20:19 06/13/06) I have a locked down parts engine Wisconsin VH4D with electric start and flywheel stator alternator. Will the VH4D flywheel work okay on the VF4D hand crank engine and will other parts interchange? Want to put electric start on the VF4D engine on a Lincoln welder. They look close to the same. Also have another parts engine V461D if anyone needs it for parts. Thanks. <br>
I am looking for a starter for a V461D do you have 1? Thanks Nelson 970-846-1440
chuckcnm
PostPosted: Thu Oct 13, 2011 7:01 pm    Post subject: Re: Wisconsin VF4D VH4D parts ?? Reply to specific post Reply with quote
Where did you drill the holes, I need to do this to mine
Post new topic    Yesterday's Tractors Forum Index -> Stationary Engines All times are GMT - 8 Hours
