4020 TRANNY'S
JD2120
PostPosted: Thu Aug 16, 2007 7:48 am    Post subject: 4020 TRANNY'S Reply to specific post Reply with quote
CAN ANYONE EXPLAIN HOW YOU GO ABOUT SHIFTING GEARS IN THE SYNCRO AND POWERSHIFT TRANNYS IN THE 4020? DID ANY OF THEM HAVE THE LO AND HI IN EACH GEAR LIKE A 4230 HAS? WHICH WAS FASTER ON THE ROAD IN 8TH GEAR?
John Jenkins
PostPosted: Thu Aug 16, 2007 8:25 am    Post subject: Re: 4020 TRANNY'S Reply to specific post Reply with quote
1. Push the clutch in to shift the Synchro, simply move the lever on the Powershift.
2. No. That was the 16-speed Quad-Range which was basically the Synchro with a 2-speed “splitter”.
3. No idea.
sodly
PostPosted: Fri Aug 17, 2007 7:58 am    Post subject: Re: 4020 TRANNY'S Reply to specific post Reply with quote
The powershift should have the higher road speed.
Gerald J.
PostPosted: Tue Aug 21, 2007 8:14 am    Post subject: Re: 4020 TRANNY'S Reply to specific post Reply with quote
In the 4020 syncro you push in the clutch and shift in the ranges (right side) which you can do while moving (though forward to reverse can be hard on the transmission) but you shift ranges (left side of shifter motion) only while stopped. Else you will grind gear teeth.
4020 power shift, you move the shifter and hang on. You don't clutch. The "clutch pedal" is only a valve to release shifting pressure. Its called an "inching pedal" in the operator's manual. There is a lever up top that releases the tranmission drive clutch, the "engine disconnect lever."
My manual isn't handy to check the relative top speeds. My gas SR 4020 does about 22 mph at full foot throttle (faster than the hand throttle) in 8th gear.
Gerald J.
