Pressure washers, Gas engine/ or electric?
Goto page 1, 2  Next
Midwest redneck
PostPosted: Tue Sep 04, 2007 1:53 pm    Post subject: Pressure washers, Gas engine/ or electric? Reply to specific post Reply with quote
I have wanted a pressure washer for a while now but......Should I get the Electric 1.5 HP for or the gas 6HP. The gas one is about $100 more but, I dont like the fact of another engine to take care of. The electric one is 120VAC 15amp. Do the electic ones work or are they junk, the one I am looking at is at Northern tool, Leeson motor made in the USA. If you have an electic one chime in here, thanks.
Charles (in GA)
PostPosted: Tue Sep 04, 2007 2:21 pm    Post subject: Re: Pressure washers, Gas engine/ or electric? Reply to specific post Reply with quote
GAS
Charles
TED In NE OH
PostPosted: Tue Sep 04, 2007 2:37 pm    Post subject: Re: Pressure washers, Gas engine/ or electric? Reply to specific post Reply with quote
I don't like to mix electric and water.
suptscottyb
PostPosted: Tue Sep 04, 2007 2:52 pm    Post subject: Re: Pressure washers, Gas engine/ or electric? Reply to specific post Reply with quote
GAS GAS GAS!
In my opinion this is not a job for an electric motor. Also pay close attention to PSI when evaluating a potential purchase. 6 horse would be a minimum, probably produce 23-2500psi. 7 or 8 hp would be better and produce 2800-3000psi. Also, ask around to learn which manufactorer makes the most reliable pumps.
The pain of disapointment outlasts the joy of a low price....
RobMD
PostPosted: Tue Sep 04, 2007 3:01 pm    Post subject: Re: Pressure washers, Gas engine/ or electric? Reply to specific post Reply with quote
I have a beautiful Dewalt (I KNOW they didn't make it, excell did!) 6.5 hp 2800 psi presure washer. The best part about this thing is the fact that it has a CAT pump on it, which is the best pump on the market.
Readily available at home depot for $629.00-ish??
SCREW electric with their stupid extension cords.
Glenn FitzGerald
PostPosted: Tue Sep 04, 2007 3:33 pm    Post subject: Re: Pressure washers, Gas engine/ or electric? Reply to specific post Reply with quote
It all depends what you plan on doing with the unit. If you will be doing stationary jobs, I'd buy an electric. I have a 10 hp. Baldor electric on a 3000+ psi 4gpm General pump. I contract cleaning on the side. It would not be hard to burn $15-$20 gas/day. Also, I like the simplicity of the electric motor setup. You do have to watch it though; most pressure washers are set at redline. If you run them for long hours and they will NOT hold up. Many pumps like mine are set up with a 7.5hp electric motor but I personally know of many of them that burned up. My 10hp Baldor will run smooth, cool, and steady around the clock for years. I used to take a little ribbing with my big/heavy ten horse. All of my critics change their tune when they toast their 7.5s. They now agree the ten horse is the way to go, but they're not cheap.
Also, I am not that enamored with Cat pumps. They are overpriced, parts are expensive, and the company is stinky at standing by their warrenty. They WILL find a way to weasel out.
I have owned/operated a pressure washer for 18 years.
Glenn FitzGerald
Doug in IL
PostPosted: Tue Sep 04, 2007 4:01 pm    Post subject: Re: Pressure washers, Gas engine/ or electric? Reply to specific post Reply with quote
I would never even consider an electric pressure washer. I know of a 22 year old farm hand who was electrocuted while using one. He was his families only child.
RayP(MI)
PostPosted: Tue Sep 04, 2007 4:34 pm    Post subject: Re: Pressure washers, Gas engine/ or electric? Reply to specific post Reply with quote
Electric ones that run on 110v are toys. You can only get so much water through a pump powered by an electric motor that"s rated at 10 to 15 amps. Serious power washers need 5hp gasoline or more. Read up on the specs on various machines and you"ll see what I mean!
msb
PostPosted: Tue Sep 04, 2007 5:25 pm    Post subject: Re: Pressure washers, Gas engine/ or electric? Reply to specific post Reply with quote
Unless you are going to use it a LOT more than most people do, go with the gas engine powered one.Gas engines on power washers rarely ever get worn out and they are a LOT more portable.Even mky old B&S starts easy, but the next one probably will be Honda powered.
LenND
PostPosted: Tue Sep 04, 2007 5:28 pm    Post subject: Re: Pressure washers, Gas engine/ or electric? Reply to specific post Reply with quote
I have a El Cheapo I use for washing my garage floor and afew other small jobs and it has worked fine for four or five years. If I was going to do more I would get a gas. As far as getting electricuted I disagree. If you got electricity to your body while using the washer it meant that you did something wrong not the machine. Maybe like not having a ground fault plug in is like asking for it with any tool - water or not.
KEB
PostPosted: Tue Sep 04, 2007 5:33 pm    Post subject: Re: Pressure washers, Gas engine/ or electric? Reply to specific post Reply with quote
I've had both...don't even bother to look at an electric one. There's a huge difference between even a bottom line gas one and an electric.
Keith
fixerupper
PostPosted: Tue Sep 04, 2007 7:23 pm    Post subject: Re: Pressure washers, Gas engine/ or electric? Reply to specific post Reply with quote
I have a small 1000 psi electric that is permanently plumbed,and well grounded, inside the shop, that works very well for quick small cleanups. It has been trouble free for many years, but for a portable one, gas is the way to go. There are no cords to mess with and most of all, it can't electrocute you.Jim
Scott.ID
PostPosted: Tue Sep 04, 2007 7:52 pm    Post subject: Re: Pressure washers, Gas engine/ or electric? Reply to specific post Reply with quote
I've had my 6.5 HP Honda powered Generac (costco) for 5 years now and it's still going strong. I did freeze the pump off of it 2 years ago, but picked up a Giant pump for about 75 bucks and haven't looked back.
I don't mix watts and water.
Scott
buickanddeere
PostPosted: Tue Sep 04, 2007 8:06 pm    Post subject: Re: Pressure washers, Gas engine/ or electric? Reply to specific post Reply with quote
The gasser will walk all over the electric in both pressure & volume. That's two items you can't get enough of.
Mike M
PostPosted: Wed Sep 05, 2007 4:42 am    Post subject: Re: Pressure washers, Gas engine/ or electric? Reply to specific post Reply with quote
Who needs another gas engine to keep running ? Not me !
I bought a Hotsy brand years ago and it works great ! I got the largest one that still runs on 110 Volts. You have to be careful as it can ruin stuff if set on 0 degree nozzle. The cleaning power of hot water is hard to beat. You can even clean in below freezing weather.
Goto page 1, 2  Next
Page 1 of 2
