Need 16” chainsaw recommendation
Goto page Previous  1, 2
Mr. Bob
PostPosted: Thu Sep 06, 2007 6:29 am    Post subject: Re: Need 16” chainsaw recommendation Reply to specific post Reply with quote
My Poulan "Wild Thing" had starting and idling problems until i had a friend of mine who used to be certified as a Poulan technician "tweak" the carb a little bit. This, along with replacing the Champion plug with Autolite made this a whole different saw. Starts good; idles good, and cuts like a "srtipped azzed ape".
Farmall Joe
PostPosted: Thu Sep 06, 2007 2:09 pm    Post subject: Re: Need 16” chainsaw recommendation Reply to specific post Reply with quote
shindaiwa (japanese i know) 357 top handle, its real small but super lite power ful for size and extreamly comfortable to use. if you want to cut down big trees go w/ husky (xp the best) there the farmall of chainsaws, underrated but will kick the crap out of a john deere
amo
PostPosted: Thu Sep 06, 2007 2:38 pm    Post subject: Re: Need 16” chainsaw recommendation Reply to specific post Reply with quote
Hussqvarna is one of the best and fastest cutting saws i have ever seen or used.
redtom
PostPosted: Thu Sep 06, 2007 5:50 pm    Post subject: Re: Need 16” chainsaw recommendation Reply to specific post Reply with quote
Every body has their favorites. Take the plastic covers off a new Husqvarna and you'll se its a poulan. They were good years ago but now are cheap. Thats why every store, Lowes,TSC etc carries them. The high end pro models probably aren't that way but they're also much more expensive. I still like my old Stihl 028's and would but a new Stihl. I was told they're one of the only ones that actually still make their own saw.
farmer boy
PostPosted: Thu Sep 06, 2007 7:00 pm    Post subject: Re: Need 16” chainsaw recommendation Reply to specific post Reply with quote
Their not all that overrated. You can't push the little consumer saws made by poulan and such companies. You pay what you get for and you pay alot for the Stihl. We have 2 of them, 038 MAGNUM and MS250. The one is 20 some years old with hundreds of hours on it and it has only had a handle and gas tank replaced because of an undertemined cause. I recently backed onto it with the tractor right up to the top handle(had to back over the lower handle to get to the top handle) and bent it very slightly out of alignment but nothing bad enough to stop it from running. The other one is 2 years old and still running strong without a single problem except it stopped running but started back up without a problem.Jonsered saws also run good but I'm not sure about longetivity and reliability. I've seen a husqvarna 257? running and that thing was deafning. Was 10-15 ft away from it and had trouble hearing after that. Can't imagine being the operator!
souNdguy
PostPosted: Thu Sep 06, 2007 9:06 pm    Post subject: Re: Need 16” chainsaw recommendation Reply to specific post Reply with quote
My P/pro was a little finecky to start / idle.. however I found that once i used a different oil than their first oil mix bottle, that it was as you say.. a "r@ped ape".
That fist little bottle of oil mix they give you must be absolute CR@P..
Soundguy
suptscottyb
PostPosted: Fri Sep 07, 2007 4:47 am    Post subject: Re: Need 16” chainsaw recommendation Reply to specific post Reply with quote
Okay. The opinions are in. Now tell us what you decided to buy and why...Thanxs!
JT
PostPosted: Fri Sep 07, 2007 10:21 am    Post subject: Re: Need 16” chainsaw recommendation Reply to specific post Reply with quote
Farmer Boy,
I can tell by your comments that you do not wrk on them for a living as I do, you are an end user the 038 and 028 are by far the best chain saws Stihl has ever built, take care of it, you have a real saw. The MS250, in 5 years, unless it is a limbing saw with minumal use, you will not be so boastful of after you use it for a while and have to pay to get the fuel lines repalced a couple of times.
Jim
Bob - MI
PostPosted: Fri Sep 07, 2007 10:50 am    Post subject: Re: Need 16” chainsaw recommendation Reply to specific post Reply with quote
Some time ago there was a survey on the site about saws. As I recall Stihl was the top rated with the usual Echo and Husky choices close thereafter.
I only use a saw occasionally and I can"t give a serious suggestion because I get by nicely for over 10 years with a 16" McCulloch for light duty and a 20" Poulan Pro for bigger stuff. The Poulan has been real sensitive to fuel age and loses power if the gas is getting old. I switched to synthetic oil and I keep the gas fresh and it does fine for my needs. I realize that many will say these saws are junk and they may well be right.
I bought the Poulan Pro for $220.00 with a case @ Lowes about 7 years ago. I was also looking at Husky"s but realized that they are the same company now and figured if I got a higher grade Poulan that I may be getting close to the Husqvarna. I have never been sure about that one however. If you are leaning towards Husqvarna check out Jack"s Small Engines. They usually have some good deals.
Best of luck on whatever you choose.
Jacks Small Engines
Jerry Eime
PostPosted: Fri Sep 07, 2007 10:06 pm    Post subject: Re: Need 16” chainsaw recommendation Reply to specific post Reply with quote
My parents own a small engine repair shop for over 25 years now and we have sold Dolmar, Redmax and Husqvarna. The only parts we have to stock for the Dolmar are spark plugs, air filters, and shock grommets. Never have we had to do a major warrenty for any engine problem, beside an oil injector leak on the 540. The Redmax is a true performer. They are a joint company that was United States and Japan but now Husqvarna bought them out because they have such great technology. And to clear up the Husqvarna issue, they only produce two saws that are made by Polan. The 137 and 142. All the rest are made in Sweeden. We have sold alot of those saws and have had no complaints. But we work on stills all day long and since we aren't a still dealer, if we can't get parts aftermarket, they are way overpriced and have come to the model of quanty over quality. If you want a saw that can take the abouse then Dolmar, Redmax or Husqvarna or even Echo. Stay away from poluns, craftsmens, and stills. Waste of money!!!
Page 2 of 2
