weight oil in cherokee?
RobMD
PostPosted: Fri Sep 07, 2007 2:40 pm    Post subject: weight oil in cherokee? Reply to specific post Reply with quote
Picked up a cherokee without an owners manual. Anyone know the factory weight and how much of oil you put in it?
10-30? 6 quarts?
thanks
Red Dave
PostPosted: Fri Sep 07, 2007 2:58 pm    Post subject: Re: weight oil in cherokee? Reply to specific post Reply with quote
You didn't say what engine is in yours, but I have a '90 with a 4.0 liter 6 cylinder. I usually use 10-30 or 10-40. Mine needs 6 quarts with a filter change.
deerhound
PostPosted: Fri Sep 07, 2007 5:25 pm    Post subject: Re: weight oil in cherokee? Reply to specific post Reply with quote
I have a 93 4.0L and 10w-30 is the specified oil in the manual. 6 quarts with a filter.
Dale
rodgernbama
PostPosted: Fri Sep 07, 2007 5:40 pm    Post subject: Re: weight oil in cherokee? Reply to specific post Reply with quote
I've got a 2001 with 4.0L engine. It takes 6 quarts w/filter 10W30.
RobMD
PostPosted: Fri Sep 07, 2007 6:12 pm    Post subject: Re: weight oil in cherokee? Reply to specific post Reply with quote
thanks a lot fellers, it is the 4.0-6
MeAnthony
PostPosted: Sat Sep 08, 2007 5:57 am    Post subject: Re: weight oil in cherokee? Reply to specific post Reply with quote
I run 10w30 in mine. Takes about 6 1/2 quarts with the 1-quart size filter. In Fram, PH3600, PH3614, PH16, PH34 and PH8A all have the same thread and gasket dimensions, just different outside dimensions.
Hope this helps.
Anthony
J.C.in AZ.
PostPosted: Sun Sep 09, 2007 9:49 am    Post subject: Re: weight oil in cherokee? Reply to specific post Reply with quote
Got an '85 with a Chev 2.8 V6,use Quaker State 20W50 with a Ph8 Fram Filter takes 5.5 Qts per change.Need 20W50 here in the Desert in summer or all year round for that matter.
