lights
jcmini
PostPosted: Fri May 23, 2008 10:13 am    Post subject: lights Reply to specific post Reply with quote
what bulbs do you use on the top of the cab on a 4430 jd
buickanddeere
PostPosted: Fri May 23, 2008 11:00 am    Post subject: Re: lights Reply to specific post Reply with quote
KEY PART NO. PART NAME QTY SG BODY SERIAL NO. REMARKS
1 R55933 SCREW 8
2 R45936 LENS 2
3 R45937 GASKET 2
4 AR48041 BULB 2 (12-VOLT)
5 12M7084 LOCK WASHER 1 0.169"
6 14H605 NUT 1 0.164"
7 AR78825 TAIL LAMP 2 (SUB FOR AR45099)
8 19H2644 CAP SCREW 2 1/2" X 2-1/2"
9 12H301 LOCK WASHER 2 1/2"
10 R59160 BRACKET 2 058881-
11 14H1040 NUT 2 058881- 1/2"
12 12H301 LOCK WASHER 2 058881- 1/2"
13 R27460 ELEC. CONNECTOR ACCESSORY 4 -058880
14 R54778 NUT 2 -058880 (ALSO ORDER R32101) (SUB FOR R50810)
15 12H301 LOCK WASHER 2 -058880 1/2"
16 R42689 BEZEL 2 (HOBBS)
R48293 BEZEL 2 (GUIDE)
17 AR42591 HEADLIGHT 2 (12-VOLT) (USE WITH AR42119)
AR104119 HEADLIGHT 2 (12-VOLT) (USE WITH RE19075)
18 WIRING LEAD 2 165 MM (6-1/2") (MAKE FROM R66319 AND (2) R32016) SEALED UNIT TO TERMINAL PLATE
19 21H1293 SCREW 4 0.164" X 5/16"
20 12M7084 LOCK WASHER 4 0.169"
21 A2899R SPRING 2
22 R30181 PLATE 2 (HOBBS)
AA3495R SUPPORT 2 (GUIDE)
23 RE19075 FLOODLAMP 2 (12-VOLT) (HALOGEN)
24 R54782 GASKET 4
25 R61179 GASKET 4
26 R54779 LENS 4
27 R54781 SCREW 8
28 AR60250 LAMP 4
29 R99350 NUT 8 (SUB FOR R53528, THIS APPLICATION)
30 AD2062R BULB 4 (12-16 VOLT)
31 R54047 BEZEL 2 NLA
32 RE25125 DUAL BEAM HEADLAMP 2 (HALOGEN) (SUB FOR AR48723)
33 RE25126 DUAL BEAM HEADLAMP 1 R.H. (FENDER, OUTER) (SUB FOR AR61325, RE10962 OR RE19081)
RE25127 DUAL BEAM HEADLAMP 1 L.H. (FENDER, OUTER) (SUB FOR AR61326, RE10963, AR25264 OR RE19082)
34 R48663 WASHER 2
35 F2935R WASHER 2
36 12H301 LOCK WASHER 2 1/2"
37 14H1040 NUT 2 1/2"
