Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
massey 165 hydraulic strainer problems
Post new topic    Yesterday's Tractors Forum Index -> Massey Harris & Massey Ferguson
chuck usny
PostPosted: Sat May 31, 2008 11:37 am    Post subject: massey 165 hydraulic strainer problems Reply to specific post Reply with quote
I've got the pto assembly bolts out as the manual states ,it wiggled out approx an inch but I cant go either way with it now ,At this point I would be happy just to get it back together although my goal was to clean the strainer which probably hasnt been done on this tractor since its birth in '74'.do I take the handle off too?i've tried it both ways as the book is lacking the real "how to ". howmuch is trying to come out of there?
DavidP, South Wales
PostPosted: Sat May 31, 2008 12:07 pm    Post subject: Re: massey 165 hydraulic strainer problems Reply to specific post Reply with quote
Hello,
To help you here a little more info on the tractor is needed. I'm guessing that your tractor is an Independant PTO type and that you have removed the bolts around the side cover on the left hand side of the tractor but are unable to get the cover back in place. Would I be correct?
If this is the case the reason why it will not fit is that there is a locating peg in the cover that engages with the IPTO unit. The unit will move and may prevent refitting.
If your tractor is a mechanical type PTO then the filter can be removed through the LH cover or through a triangular plate on the underside of the centre casing. Tricky, but not too difficult. If it is an IPTO tractor then it will be necessary to split the tractor between the centre casing and gearbox in order to gain access.
Let us know what you have.
Cheers
DavidP, South Wales
chuck usny
PostPosted: Sat May 31, 2008 12:19 pm    Post subject: Re: massey 165 hydraulic strainer problems Reply to specific post Reply with quote
This is a 1974 massey ferguson 165 diesel ,Its a manual pto ,the lever is on the outside of the cover the book tells me; to remove ,pull out assembly ,reach in and turn wing nut and pull out strainer screen. however I cant remove the assembly something is still attached somewhere.
chuck usny
PostPosted: Sat May 31, 2008 12:34 pm    Post subject: Re: massey 165 hydraulic strainer problems Reply to specific post Reply with quote
Okay it may be a Ipto I guess, whats the differece ,I'm not understanding when you say manual you dont mean ....... a manual lever do you? okay so I'm slow.......I really need to know what may still be holding it in. is it a pull and turn or a pull and disconnect the thingamabob next the whichamajigger. I'm stressed out .Thanks David
Bob N.Y.
PostPosted: Sat May 31, 2008 2:06 pm    Post subject: Re: massey 165 hydraulic strainer problems Reply to specific post Reply with quote
Live PTO = 2 stage clutch. You depress the clutch pedal half way to stop the ground travel without stopping the PTO. Depress the pedal all the way to stop the PTO also. Independant PTO is engaged by a hydraulic clutch that controlled by the lever by your left heel. The foot clutch has no effect at all on IPTO.
chuck usny
PostPosted: Sat May 31, 2008 2:16 pm    Post subject: Re: massey 165 hydraulic strainer problems Reply to specific post Reply with quote
Oh alright,2 stage clutch so I have a manual.hi Bob,any ideas whats holding this unit from coming out so I can clean the screen?where in Ny,I could use an extra set of hands......hahaha
chuck usny
PostPosted: Sat May 31, 2008 4:38 pm    Post subject: Re: massey 165 hydraulic strainer problems Reply to specific post Reply with quote
The books says to just pull it out ,but Its hung up or still attached, is there a place to go to see what the inside of this might look like?
DavidP, South Wales
PostPosted: Sun Jun 01, 2008 1:59 am    Post subject: Re: massey 165 hydraulic strainer problems Reply to specific post Reply with quote
Hello again,
Just to confirm, do you have to press the clutch pedal to engage the PTO or not?
If not you have a mechanical PTO. When the cover is off you can see the upturned cup that covers the filter. There should be a locking wire normally to the back plate of the pump. Cut the wire. You will find it easier if you have a small pair of pliers to grip the plate on top of the cup. Although it is only an O ring that holds it it can be uncomfortably tight and painful to undo by hand. When you have removed the cup and strainer there is a second cup with the O ring underneath it.
If you have an IPTO tractor you will need to undo the IPTO pressure test point before you can remove the cover and also any pipework that may be fitted for the aux hydraulics.
Cheers
DavidP, South Wales.
Bob N.Y.
PostPosted: Sun Jun 01, 2008 4:38 am    Post subject: Re: massey 165 hydraulic strainer problems Reply to specific post Reply with quote
I am in Herkimer County, north of the Thruway. Wher are you?
chuck usny
PostPosted: Sun Jun 01, 2008 6:09 am    Post subject: Re: massey 165 hydraulic strainer problems Reply to specific post Reply with quote
30 mins south of cortland
Bob N.Y.
PostPosted: Sun Jun 01, 2008 6:52 am    Post subject: Re: massey 165 hydraulic strainer problems Reply to specific post Reply with quote
It is about 3 hours from here to Ithaca. It would be the same to where you are.
chuck usny
PostPosted: Sun Jun 01, 2008 6:16 pm    Post subject: Re: massey 165 hydraulic strainer problems Reply to specific post Reply with quote
okay ,I've borrowed a manual that explains a little more ,which inturn has me scared .I now am unsure what it is (Ipto) I only had this 1 year and have never needed the pto so I dont know how it works. it has a bucket and thats all I've used it for.the little bit i have this cover pulled out I see a small line attached. now my issue is the mf manual contradicts itself. it says to to remove the top cover under the seat I need to go into the response cover and reach in and spead the forks and take out roller, then in the response lever directions it says I 1st need to remove the top cover .which is it?
