8N spark plugs
Spottie
PostPosted: Tue Jun 10, 2008 10:25 am    Post subject: 8N spark plugs Reply to specific post Reply with quote
I have a 1950 Ford 8N tractor and want to replace the plugs after owning it a couple years. I ordered the tune up kit listed for my tractor's serial number. When I opened it, I found Autolite 437 plugs. However, the plugs currently in my tractor are Autolite 216. It has a side mount distributor, if that is important to this discussion. Anyway, I don't know if those 216 plugs are the wrong ones, if the 437 are wrong, or if it just doesn't matter. I am a newbie to this antique tractor stuff, so I need help! Thank you!
Colin King
PostPosted: Tue Jun 10, 2008 10:32 am    Post subject: Re: 8N spark plugs Reply to specific post Reply with quote
437 is the correct plug. Gap them to 0.025.
Colin, MN
Leemo
PostPosted: Tue Jun 10, 2008 10:36 am    Post subject: Re: 8N spark plugs Reply to specific post Reply with quote
Like Colin indicated the 437s are good. they're a slightly hotter plug than the 216s and seem to have less problems with fouling in these old tractors.
old
PostPosted: Tue Jun 10, 2008 10:39 am    Post subject: Re: 8N spark plugs Reply to specific post Reply with quote
The 437s seem to be the ones that most people use. Reason is they run a little hotter and because they run hotter there less likely to foul out
Bruce (VA)
PostPosted: Tue Jun 10, 2008 10:40 am    Post subject: Re: 8N spark plugs Reply to specific post Reply with quote
They will actually work better than the 216's. See tip # 7 at the link below.
50 Tips
Dell (WA)
PostPosted: Tue Jun 10, 2008 10:57 am    Post subject: Re: 8N spark plugs Reply to specific post Reply with quote
Spottie.........the OEM sparkies in 1939 were cool Champion H-10's. The AutoLite 216 is the cool Champion replacement. Modern "no-lead" gasoline causes cool sparkies to FOUL and misfire. Also oil-burners need HOT sparkies too. The hotter Champion is H-12 but for some reason FOUL too. The hotter AutoLite equivalent of H-12 is AutoLite 437 and they DON'T FOUL. (we don't know why) That is why we recommend AutoLite 437's. (gap = 0.025in) Hope this "educates" you some.........Dell, yer self-appointed sparkie-meister
souNdguy
PostPosted: Tue Jun 10, 2008 10:59 am    Post subject: Re: 8N spark plugs Reply to specific post Reply with quote
Ditto everybody else.. 437's ar ethe way to go.
soundguy
Spottie
PostPosted: Tue Jun 10, 2008 2:00 pm    Post subject: Re: 8N spark plugs Reply to specific post Reply with quote
Thank you so much for your help. I can't wait for the weekend so I can do my tune up. Thank you Thank you!!!
Dunk
PostPosted: Tue Jun 10, 2008 2:43 pm    Post subject: Re: 8N spark plugs Reply to specific post Reply with quote
For anyone that would like to know a cross of the 437s to different brands (i.e. NAPA X526), poke here, plug specs are also at the far right on the chart.
http://theviperr.com/8n/437-cross.mht
jmazzei59
PostPosted: Mon May 11, 2009 8:10 am    Post subject: Re: 8N spark plugs Reply to specific post Reply with quote
Colin King wrote:
(quoted from post at 11:32:19 06/10/0Cool 437 is the correct plug. Gap them to 0.025.
Colin, MN
I also have a 1950 8n tractor. Since I changed the spark plugs, the throttle lever next to the steering wheel, won't stay all the way down, or all the up, it kind of springs to the middle. In order to keep the engine reved up, I have to manually hold the lever. Also, since I changed the plugs, I don't have very much power, it bogs down when I cut grass.
Can you help this city boy ???
jmazzei59
PostPosted: Mon May 11, 2009 8:15 am    Post subject: Re: 8N spark plugs Reply to specific post Reply with quote
