wiring digram for 6 volt mag 1942 farmall H
Rich ORourke
PostPosted: Tue Aug 26, 2008 5:55 pm    Post subject: wiring digram for 6 volt mag 1942 farmall H Reply to specific post Reply with quote
I finally got the lights to work, but does anyone have a wiring diagram for a 1942 Farmall H with 6 volt mag system and two head lights and one headlight for the back impliment side? The tractor starts right up, but I do not have a clue where all the wires should go. the previous owner was no mechanic!!! Should I use all 12 guage wire? I want to make it like it was originally! thanks, I need to know how the wires should go from the generator to the voltage regulator and how they tie in to the foot starter switch and so on. thanks, Rich
ryanroth
PostPosted: Tue Aug 26, 2008 6:13 pm    Post subject: Re: wiring digram for 6 volt mag 1942 farmall H Reply to specific post Reply with quote
go back a couple of posts for wiring an M. there is a link for Bob's diagrams. there is a diagram on that link. i have the same in a 44' model. Also try porch electric for authentic wire harness for this tractor. around $80
Janicholson
PostPosted: Tue Aug 26, 2008 6:14 pm    Post subject: Re: wiring digram for 6 volt mag 1942 farmall H Reply to specific post Reply with quote
Here are the diagrams #4 is the one you will need I think. The light Switch system is detailed in a different diagram. JimN
Bob Ms marvelous diagrams
boomer22
PostPosted: Tue Aug 26, 2008 6:18 pm    Post subject: Re: wiring digram for 6 volt mag 1942 farmall H Reply to specific post Reply with quote
Try these they are the best I've found.
Click here ---> Bob's Diagrams
Gene Bender
PostPosted: Tue Aug 26, 2008 6:38 pm    Post subject: Re: wiring digram for 6 volt mag 1942 farmall H Reply to specific post Reply with quote
If you are going to use #4 better put a wire from the F on the Gen to the F on the cut-out or it just wont work. You cant get the gen to charge without a wire from the gen to the cut-out.
Rich ORourke
PostPosted: Wed Aug 27, 2008 4:14 am    Post subject: Re: wiring digram for 6 volt mag 1942 farmall H Reply to specific post Reply with quote
thanks you very much,Rich
Rich O'Rourke
PostPosted: Wed Aug 27, 2008 4:15 am    Post subject: Re: wiring digram for 6 volt mag 1942 farmall H Reply to specific post Reply with quote
thank you very much
Rich ORourke
PostPosted: Wed Aug 27, 2008 4:16 am    Post subject: Re: wiring digram for 6 volt mag 1942 farmall H Reply to specific post Reply with quote
thank you very much, Rich
Rich ORourke
PostPosted: Wed Aug 27, 2008 4:19 am    Post subject: Re: wiring digram for 6 volt mag 1942 farmall H Reply to specific post Reply with quote
thank you, Rich
Janicholson
PostPosted: Wed Aug 27, 2008 1:03 pm    Post subject: Re: wiring digram for 6 volt mag 1942 farmall H Reply to specific post Reply with quote
The mag is, as I stated, not connected to anything but the mag Kill switch in the electrical box. (push pull, on off switch)
That switch is a single terminal switch that grounds the wire attached to it when the switch is pushed in, and opens (allowing mag operation) when pulled out.
No modifications are made to any part of the ignition Mag or grounding switch or the single wire running to it.
Assuming a three wire SI10 GM delco alternator.
The alternator should be connected as follows:
a #10ga wire connects to the big "bolt on" terminal on the alternator. From there it is connected to the amp gauge, on the load side of the gauge (the side not attached to the Battery + side through the Starter Switch) Using a Fuse link saves burnt parts and fires. NAPA has them, (crimp on, not solder) JimN
New diagram for mag and alternator
JOSSETTE
PostPosted: Wed Aug 27, 2008 1:09 pm    Post subject: Re: wiring digram for 6 volt mag 1942 farmall H Reply to specific post Reply with quote
dfg
