Does a 5020 have a 540 pto?
alabamafrog
PostPosted: Tue Sep 30, 2008 2:02 pm    Post subject: Does a 5020 have a 540 pto? Reply to specific post Reply with quote
Dad is looking at buying a 5020, he says its around 140hp and would pull the new baler good but he said it has a 1,000rpm pto and he wanted me to ask yall if it was also compatible with 540 pto equipment and what it would take to swap it over.
David from Kansas
PostPosted: Tue Sep 30, 2008 2:13 pm    Post subject: Re: Does a 5020 have a 540 pto? Reply to specific post Reply with quote
The 5020 has 1000 RPM PTO only.
alabamafrog
PostPosted: Tue Sep 30, 2008 2:24 pm    Post subject: Re: Does a 5020 have a 540 pto? Reply to specific post Reply with quote
Thanks for the info, that’s kinda what we figured. Well I guess that means it would be a useless tractor for us since all of our equipment is 540. I wonder why they made it that way.
Glen D Anderson
PostPosted: Tue Sep 30, 2008 2:34 pm    Post subject: Re: Does a 5020 have a 540 pto? Reply to specific post Reply with quote
"Improvement"............higher speed = less torque = smaller parts to transmit more HP...................
alabamafrog
PostPosted: Tue Sep 30, 2008 2:46 pm    Post subject: Re: Does a 5020 have a 540 pto? Reply to specific post Reply with quote
I was hoping the 5020 would be like our 4020 or 4010 and be interchangeable between 1000 and 540. Dad has also found a 9600 Ford ~135hp, we wanted to stay green but sounds like we’ll have no choice but to add a blue tractor to the barn. Anyone know of any problem areas to look for on the 9600 Ford?
buickanddeere
PostPosted: Tue Sep 30, 2008 3:56 pm    Post subject: Re: Does a 5020 have a 540 pto? Reply to specific post Reply with quote
A baler large enough to require a 100+HP tractor would be available in 540 or 1000rpm.Or it would be field convertible from 540 to 1000rpm.
Somebody here a few months ago posted a link to a company making some very beefy tractor mounted 1000 to 540 reduction boxes.
Gerald J.
PostPosted: Tue Sep 30, 2008 4:31 pm    Post subject: Re: Does a 5020 have a 540 pto? Reply to specific post Reply with quote
150 hp at 540 rpm will twist off the splined shaft.
Gerald J.
Glen D Anderson
PostPosted: Tue Sep 30, 2008 6:40 pm    Post subject: Re: Does a 5020 have a 540 pto? Reply to specific post Reply with quote
Yes,
1459 lbs/ft of torque at 540 rpm VS. 787 lbs/ft of torque at 1000 rpm.......................
R. Williams
PostPosted: Tue Sep 30, 2008 8:37 pm    Post subject: Re: Does a 5020 have a 540 pto? Reply to specific post Reply with quote
9600 Ford should be cheap horse power.
The injector pump needs the oil changed ever time the motor oil is changed or it will cost you money. The rear wheels have a tendency to work back and forth on the axle. That was my problems and a weakness that I noticed on others.
Ralph
low budget
PostPosted: Wed Oct 01, 2008 3:07 am    Post subject: Re: Does a 5020 have a 540 pto? Reply to specific post Reply with quote
I have a 5020 that I use mostly as a toy, take it to local tractor pulls. I have added a turbo and played with the pump a bit. It has enough power to handle any 540 implement I've hooked to it, including a forage harvester. I keep the tractor at about 1300 engine rpm or less.
Probably the Ford 9600 would be better for you. I have heard of them twisting the 540 shaft right off however. I dont know alot about the bigger Fords, but I have a 5000 and a 7700, they are very reliable. Post a question on the Ford board. There are some very knowledgeable guys over there.
