2008 JD 135LE With a Craftsman SnoCab installed
Haywood
PostPosted: Fri Jan 23, 2009 4:15 pm    Post subject: 2008 JD 135LE With a Craftsman SnoCab installed Reply to specific post Reply with quote
This only required a slight Modification to work on this 2008 JD 135LE.
I cut the lower tubes until there was 3 mounting holes left.
I mounted the main Fender Bracket so the tubes would tip downward, this positioned the bar vertically. Used the L brackets supplied in the Kit to mount on the front holes of the tube on each side. The front support installed as viewed in instructions, but I added some plastic fasteners to keep the support from sliding around. The Rear bar Assembly mounted farther Back than pictured for a Craftsman installation. However it was located in the proper location for a good fit. I Plan on buying some Rip Stop nylon and Clear Vinyl & sewing a panel to attach to the rear of the open cab.
The Cab fits like it was made for the Tractor.
[/img]
Dude11
PostPosted: Sat Jan 24, 2009 6:12 am    Post subject: Re: 2008 JD 135LE With a Craftsman SnoCab installed Reply to specific post Reply with quote
OH,the JD gurus are going to rain down on you for that one!!Better cover up the logo,quick.Just kidding,It looks great,and if it keeps you out of the cold,I wouldn't care if it had JC.Higgins stamped on it.Dude11
