7.8 ford truck engine swap with ford 9600 401
david futrell
PostPosted: Mon Apr 06, 2009 10:18 am    Post subject: 7.8 ford truck engine swap with ford 9600 401 Reply to specific post Reply with quote
does anyone out there know if a ford 7.8 inline six swap out with a ford 401 diesel in a 9600 ford
RodinNS
PostPosted: Mon Apr 06, 2009 1:39 pm    Post subject: Re: 7.8 ford truck engine swap with ford 9600 401 Reply to specific post Reply with quote
Well... if you're building a puller and have unlimited dollars, then I'd say it can be done. If you're replacing a busted block in a farm tractor, find an engine from another 9600.
There would be a bunch of subtle differences if you get down to looking at those engines. Flywheels and their bolt patterns would probably be one. I also don't think the 7.8L engine is really intended as a 'structural' block whereas the 401 was... In short, it will cost far more to do the swap than a good running 401 and probably more than a longblock.
Rod
Bern
PostPosted: Mon Apr 06, 2009 2:50 pm    Post subject: Re: 7.8 ford truck engine swap with ford 9600 401 Reply to specific post Reply with quote
In addition to what Ron said, the 7.8L (and 7.5L Genesis) blocks are taller. This will cause misalignment problems with everything from the fan to the rear support bracket. I don't think it's worth the hassle.
david futrell
PostPosted: Mon Apr 06, 2009 4:16 pm    Post subject: Re: 7.8 ford truck engine swap with ford 9600 401 Reply to specific post Reply with quote
is there an industriaul engine that will swap this is going to be a puller
Lumpy
PostPosted: Mon Apr 06, 2009 5:18 pm    Post subject: Re: 7.8 ford truck engine swap with ford 9600 401 Reply to specific post Reply with quote
Becareful about what you are wanting to swap in. When it comes to rule books and what classes you are thinking about running. If you are building a S.F. or P.S., I believe you MUST run a block mfg by what ever tractor you are building. Example: If you pull a I.H, you have to run a I.H block. It can be out of a dozer or dump truck, but it still has to be a I.H block.
showcrop
PostPosted: Tue Apr 07, 2009 5:04 pm    Post subject: Re: 7.8 ford truck engine swap with ford 9600 401 Reply to specific post Reply with quote
David, probably the best known older ford hot farm puller in the country uses the genesis engine. I was looking at it about three weeks ago. It has a separate structural frame, but still uses the original cases. I pull with a stock 9000 myself.
