CUB Belly Mower Belt
Tree Killer
PostPosted: Sun Apr 19, 2009 3:29 pm    Post subject: CUB Belly Mower Belt Reply to specific post Reply with quote
My 1948 Cub will not keep the belt on the woods belly mower under it. Keeps throwing it off. Tried everything. Put a Napa 140 belt on it, same as before. It seems to twist and then come off. Please Help.
Tree Killer
Rusty wheel
PostPosted: Sun Apr 19, 2009 3:59 pm    Post subject: Re: CUB Belly Mower Belt Reply to specific post Reply with quote
If it's throwing off new belts, I would think either something is out of line or the belt guides need adjusted. rw
glennster
PostPosted: Sun Apr 19, 2009 4:26 pm    Post subject: Re: CUB Belly Mower Belt Reply to specific post Reply with quote
i gotta look around, i think i have a copy of the belt adjustment set up for the woods 59 belly mower. i have a 59 under my cub and also one on by b. i have not had any luck with belts from napa or berry bearing on the woods mowers, barely lasted a year. i got my last belts from case-ih, and they have been running for over 5 years now.
Haas
PostPosted: Sun Apr 19, 2009 4:53 pm    Post subject: Re: CUB Belly Mower Belt Reply to specific post Reply with quote
If you don't have a manual for the Woods mower that tells how to install and adjust the belts and pulleys, go to the Woods website. All the mower manuals are on line and you can download the one for the Cub. If a new belt is jumping off, something is not set correctly.
Slappy
PostPosted: Mon Apr 20, 2009 4:15 am    Post subject: Re: CUB Belly Mower Belt Reply to specific post Reply with quote
Most belts have Kevlar or similar bands in them that keep them from streching. If you"ve hit anything with the mower heavy enough to strain the belt you may have broken those bands. If so, it won"t matter how much you tighten, the give in the belt will allow it to strech enough to slip the pulley.
My wife will forget where the stumps are every once in a while and whack one of the little buggers with the International mower on our Cub. I"ll put the belt on and it will go maybe 15 minutes and throw the belt, after that it won"t run 5 minutes before the belt"s off.
Put on a new belt and it will run just fine - at least until we try to mow down another stump.
glennster
PostPosted: Mon Apr 20, 2009 4:38 am    Post subject: Re: CUB Belly Mower Belt Reply to specific post Reply with quote
found it, here is the adjustments for the belt.
Photobucket
Photobucket
Untitled URL Link
rustyfarmall
PostPosted: Mon Apr 20, 2009 7:42 am    Post subject: Re: CUB Belly Mower Belt Reply to specific post Reply with quote
I assume the belt on yours is routed the same as on my Woods L306. The belt requires a 1/2 twist on the left side, and 3/4 twist on the right side. (as viewed from the driver seat) If the left and right side twists are not correct, that belt absolutely WILL NOT stay on.
The voice of experience
