IH 656 whinning noise
Watertown Larry
PostPosted: Sat May 09, 2009 12:48 pm    Post subject: IH 656 whinning noise Reply to specific post Reply with quote
I am in the process of selling and IH 656 tractor for a deceased neighbor. When I start the tractor up and while it is running it makes all whining noise that seems to be coming from the transmission area. I have checked the trans-hydraulic fluid level and that is okay. Someone suggested that it might be the hydraulic pump. Any other ideas of what I might do to correct this problem? Thank you for any help you can provide.
INDIANA CLYDE
PostPosted: Sat May 09, 2009 2:12 pm    Post subject: Re: IH 656 whinning noise Reply to specific post Reply with quote
my 454 will do that when the hydro filter needs to be replaced
Hugh MacKay
PostPosted: Sat May 09, 2009 3:36 pm    Post subject: Re: IH 656 whinning noise Reply to specific post Reply with quote
Larry: Hydraulic filter, and if it's been plugged long enough, pump could be trouble as well.
Allan in NE
PostPosted: Sat May 09, 2009 3:38 pm    Post subject: Re: IH 656 whinning noise Reply to specific post Reply with quote
The hydraulic filter is plugged and the noise you hear is the bypass valve working overtime.
Change that filter, clean the bypass screen and it should shut right up.
Allan
Farmboy856
PostPosted: Sat May 09, 2009 5:38 pm    Post subject: Re: IH 656 whinning noise Reply to specific post Reply with quote
I agree with all the others, but one other thought crossed my mind: Is this by chance a 656 Hydro (Hydrostatic drive) tractor? If so, the Hydro unit will whine sometimes even sitting still while the engine is running, and there will be a pronunced whining when the tractor is moving with or withut a load on it. My grandad bought new one of the first 1026 Hydros sold in this area, and the neighbors always claimed you could here it all over the neighborhood, especially when we were plowing. We"ve had several others since, and still have a gas 656 Hydro, and they all had that whine, especially when moving. My Cub Cadet 1250 (almost identical drive type of system) still whines whenever it"s in motion. It"s just a peculiarity of the beast. Just a thought.
