Farmall M Hydraulic Fluid
butch force
PostPosted: Sun May 10, 2009 11:44 am    Post subject: Farmall M Hydraulic Fluid Reply to specific post Reply with quote
Just inherited a Farmall M. I know this is basic, but is there any way to check the level of the hydraulic fluid? I am assuming you fill it on the right side as one sets on the tractor. Does it take HY-Tran or motor oil. Tahnks all
Roy Ward
PostPosted: Sun May 10, 2009 12:27 pm    Post subject: Re: Farmall M Hydraulic Fluid Reply to specific post Reply with quote
30 weight motor oil. There is a drain plug in the center of the bottom of the pump. There should be a dip stick attached to the cap on the right side of the tractor. Empty it should take about 1 Gal. If it's and older unit I like to add some STP.
Butch force
PostPosted: Sun May 10, 2009 2:14 pm    Post subject: Re: Farmall M Hydraulic Fluid Reply to specific post Reply with quote
Thanks Roy. I am going out now to look again, but I did not see a dip stick when I took the cap off. Matter of fact, I have inherited three H's and did not see a dip stick on any of them. Thanks again
Cub n M in OR
PostPosted: Sun May 10, 2009 2:35 pm    Post subject: Re: Farmall M Hydraulic Fluid Reply to specific post Reply with quote
They called for 30w non detergent orriginally. I run Regular hydraulic fluid in mine so I can hook onto any equipment without cross contamination.
Most of those old dipsticks are long gone. if you overfill, it will just overflow. I think 6 quarts is the capacity.
Ben
Butch force
PostPosted: Sun May 10, 2009 2:54 pm    Post subject: Re: Farmall M Hydraulic Fluid Reply to specific post Reply with quote
OK, I have a spare from one of the H's that I imagine will work. Now that I have a template, I can always fab one up. Is there suppose to be packing in the top of the filler cap? There is also a brass fitting with a screw on the filler cap, I imagine that is some kind of vent or relief system.
I notice the M has a valve on the filler side to regulate implements to the rear of the tractor. nice touch. Tahnks all.
Roy Ward
PostPosted: Sun May 10, 2009 3:00 pm    Post subject: Re: Farmall M Hydraulic Fluid Reply to specific post Reply with quote
They didn't secure it well and in some cases they fell in to the pump. You might just screw off that pipe and with a magnet feel around for it. It should be about 6 inches long. It attaches to the cap with a pin.
Hyd fluid has been used but your pump tolerances needs to be more than perfect or you will get less pressure when the oil is hot.
Butch force
PostPosted: Sun May 10, 2009 3:21 pm    Post subject: Re: Farmall M Hydraulic Fluid Reply to specific post Reply with quote
Well, I guess I can always put a small TIG bead on the small round disk and dip stick to hold it in place. Thanks, I did think about putting a magnet in and digging around. Will check it out tomorrow. Any idea about the brass screw on the cap? May be an after thought by previous owners.
I like this tractor. Have to investigate a three point.
john d
PostPosted: Sun May 10, 2009 3:38 pm    Post subject: Re: Farmall M Hydraulic Fluid Reply to specific post Reply with quote
Brass screw may or may not have been IH, or even dealer installed. My M does not have it, but my SM does. I'm guessing it lets the air out of the pump reservoir a little more quickly.
If your pump is worn much, SAE 30 may work better than Hy-Tran when it warms up. NON-detergent SAE 30 is recommended. SAE 40 may help if the pump is worn a little.
It holds about 6 quarts. I have a loader on my M. It has no dipstick. When it won't quite lift all the way up, it's time for another quart!
Butch Force
PostPosted: Sun May 10, 2009 4:48 pm    Post subject: Re: Farmall M Hydraulic Fluid Reply to specific post Reply with quote
John D,
thanks. Wouldn't it be great of my M was indeed a SM??? Doubt if I am that fortunate. Assume you have no problems switching/mixing implements with HY-Tran and 30 or 40 weight. Is there a pressure test one can do to verify the pumps condition?
D Slater
PostPosted: Sun May 10, 2009 5:01 pm    Post subject: Re: Farmall M Hydraulic Fluid Reply to specific post Reply with quote
The brass vent that could be opened or closed was original equipment when a remote control valve was installed. Thats the valve that will operate a hydraulic cylinder 2 ways. If you have the IH remote control and parts the dipstick had 2 joints that let it bend to get in and out. Full mark was about 12-3/4 inches down from under cap. Without remote control valve installed the dipstick was straight. Full mark about 9-1/2 inches down from where cap mounts.
Butch Force
PostPosted: Sun May 10, 2009 5:25 pm    Post subject: Re: Farmall M Hydraulic Fluid Reply to specific post Reply with quote
D Slater, well that clears allot up. Obviously, a shop manual a near term purchase. Thanks much
Andy Martin
PostPosted: Mon May 11, 2009 4:23 am    Post subject: Re: Farmall M Hydraulic Fluid Reply to specific post Reply with quote
I think the original dip sticks were captured in a hole in the disc to allow them to swing. Welding them on may result in premature breakage due to vibration.
butch force
PostPosted: Mon May 11, 2009 3:32 pm    Post subject: Re: Farmall M Hydraulic Fluid Reply to specific post Reply with quote
thanks andy, thats a good point I did not think of
