I HAVE SPARK
Goto page 1, 2  Next
brownchristian
PostPosted: Tue Aug 18, 2009 5:22 pm    Post subject: I HAVE SPARK Reply to specific post Reply with quote
thats all Laughing
FLAcharlie
PostPosted: Tue Aug 18, 2009 5:27 pm    Post subject: Re: I HAVE SPARK Reply to specific post Reply with quote
well when you LOSE spark, and get it BACK, there is certainly no better feeling.
The same goes for your tractor !
Congrats !
brownchristian
PostPosted: Tue Aug 18, 2009 5:33 pm    Post subject: Re: I HAVE SPARK Reply to specific post Reply with quote
I never had spark and it is a great feeling. Now just hope it will start once I get it all put back together. Rolling Eyes
Dunk
PostPosted: Tue Aug 18, 2009 5:48 pm    Post subject: Re: I HAVE SPARK Reply to specific post Reply with quote
brownchristian wrote:
(quoted from post at 22:33:36 08/18/09)
I am going to celebrate!!!!
JMOR
PostPosted: Tue Aug 18, 2009 7:04 pm    Post subject: Re: I HAVE SPARK Reply to specific post Reply with quote
What was the magic single item that gave you spark?
GB in MT.
PostPosted: Tue Aug 18, 2009 7:36 pm    Post subject: Re: I HAVE SPARK Reply to specific post Reply with quote
JMOR wrote:
(quoted from post at 22:04:18 08/18/09) What was the magic single item that gave you spark?
Yeh....I want to know too!!!
John P.
PostPosted: Wed Aug 19, 2009 2:22 am    Post subject: Re: I HAVE SPARK Reply to specific post Reply with quote
So what was the problem???
brownchristian
PostPosted: Wed Aug 19, 2009 3:17 am    Post subject: Re: I HAVE SPARK Reply to specific post Reply with quote
Went to the auto parts to find parts for my distributor. After an hour of searching through the shelves and a book we found the points. Still no cap or rotor. Gapped the new points. Put a new connection on the coil wire. Nice blue spark.
Now I need to find a cap and rotor. The cap has a number if IBK-1009 stamped on the inside. I find a reference to it online but have been unable to find one for sale. Also found that it is cross referenced to Prestolite 3-129. Maybe one of you gurus know where to find all the info.
BTW, the points were BWD model A81. Really wish I could find the specifics on this distributor.
Dunk
PostPosted: Wed Aug 19, 2009 3:21 am    Post subject: Re: I HAVE SPARK Reply to specific post Reply with quote
(quoted from post at 08:17:08 08/19/09) Went to the auto parts to find parts for my distributor. After an hour of searching through the shelves and a book we found the points. Still no cap or rotor. Gapped the new points. Put a new connection on the coil wire. Nice blue spark.
Distributor Cap
Product Line: Echlin Ignition
Interchange Mfg.: Prestolite
Interchange Mfg. Part Number: IBK1009 ECH AL165
Unit: 36.99 Each
Distributor Cap Rotor # : AL150
That is from http://napaonline.com
They are quite proud of those caps aren't they.
Too bad they won't tell me what they fit.
brownchristian
PostPosted: Wed Aug 19, 2009 3:24 am    Post subject: Re: I HAVE SPARK Reply to specific post Reply with quote
Dunk how did you find it so quickly. I consider myself and internet search guru and couldn't find anything. I still can't find it when I do a search on the napa website.
Now can you tell me what distributors this cap fits so I can try an determine what I have?
Dunk
PostPosted: Wed Aug 19, 2009 3:30 am    Post subject: Re: I HAVE SPARK Reply to specific post Reply with quote
(quoted from post at 08:24:26 08/19/09)
Go to NAPAOnline, and go to the Parts Pro catalog search.
(I have been on the Internet since before it had pictures, or HTML)
Now on YT parts I find this.
Electronic Ignition Conversion Kit - 12 V Negative Ground - 12 Volt NEGATIVE ground (Also available in 12V POS , 6V NEG and 6V POS - CALL) For the following models using Autolite IAD-6003, IAD6003-2F and IAD6004 distributors (VERIFY your distributor for match): VA, VAC, VAE, VAI, VAO, VAS, 150, 200, 200B, 210, 210B, 211B, 300, 302, 310, 320, 350B, 351, 400, 400B, 430, 440, 441, 450, 500, 530, 540, 540C, 541, 541C, 580CK, 600B, 640, 640C, 641, 641C, 650, 655, 675, 1150, 1155, 1255. Electronic ignition conversion kit, replaces points and condenser with an electronic module. Use with 12 volt negative ground system. MUST ALSO REPLACE CAP (AL165) and ROTOR (AL150) both available from auto parts store. (Part No: 1541)
http://www.ytmag.com/store/parts/casecat.htm
That is on a Case, David Brown, parts page.
JMOR
PostPosted: Wed Aug 19, 2009 3:34 am    Post subject: Re: I HAVE SPARK Reply to specific post Reply with quote
(quoted from post at 07:24:26 08/19/09)
If it can be found on the net, Dunk, will find it.
Based on his cap find & the fact that Prestolite made distributors for many applications, I suspect it is a Prestolite distributor. Prestolite as a company went away. probably sucked into BWD or some other company a long time back.
GB in MT.
PostPosted: Wed Aug 19, 2009 4:18 am    Post subject: Re: I HAVE SPARK Reply to specific post Reply with quote
BIG FAT KUDO's for Dunk............again!!!!!!!!!!!!!
Gary Cool
brownchristian
PostPosted: Wed Aug 19, 2009 7:17 am    Post subject: Re: I HAVE SPARK Reply to specific post Reply with quote
Look what I found.
http://ford8n.com/f8shop/index.cgi?ID=CCTY55&task=show&cat=MANUALS&pgidx=37
Four items down.
brownchristian
PostPosted: Wed Aug 19, 2009 7:19 am    Post subject: Re: I HAVE SPARK Reply to specific post Reply with quote
Here it is again.
http://www.ytmag.com/store/product_files/IBK1009_12391.htm
Goto page 1, 2  Next
Page 1 of 2
