Looking for better air filter for 54 Ford NAA Tractor.
733Memphis
PostPosted: Sun Aug 30, 2009 7:48 pm    Post subject: Looking for better air filter for 54 Ford NAA Tractor. Reply to specific post Reply with quote
Does anyone know of a better air filter for a 54 Ford NAA tractor than the factory oil bath air filter? I am looking for some type of after market paper cartrige type of air filter and housing, preferably with a pre-filter foam cover. I do a lot of mowing and tillage in dusty conditions and I am looking for a better air filter system for my 54 Ford NAA tractor.
Bob
PostPosted: Sun Aug 30, 2009 8:22 pm    Post subject: Re: Looking for better air filter for 54 Ford NAA Tractor. Reply to specific post Reply with quote
Actually, you can't beat the original system so long as you change the oil in the bottom cup as often as conditions warrant.
Contrary to marketing hype the oiled gauze filters being sold nowadays for big bucks actually do a really s h i t t y job of keeping dirt out of the engine.
So stop trying to make things better by actually making them WORSE!
old
PostPosted: Sun Aug 30, 2009 8:24 pm    Post subject: Re: Looking for better air filter for 54 Ford NAA Tractor. Reply to specific post Reply with quote
Oil bath how can you improve on it???????????????? It is the best for dusty conditions and has worked well for 50 plus years. Nothing better for dust etc etc etc
john in la
PostPosted: Sun Aug 30, 2009 8:25 pm    Post subject: Re: Looking for better air filter for 54 Ford NAA Tractor. Reply to specific post Reply with quote
Do you really want better or easier.
I do not think you will find a better air filter than a oil bath system but paper cartrige would be eaiser.
Now if you really want better one of the larger oil bath filters that mounts on the side of the hood may be better.
GlenIdaho
PostPosted: Sun Aug 30, 2009 8:27 pm    Post subject: Re: Looking for better air filter for 54 Ford NAA Tractor. Reply to specific post Reply with quote
Memphis;
I've not seen any after market kits for your tractor. The subject comes up from time to time about a conversion. With a little ingenuity you can make one yourself. However, over the years the consenus seems to be that the oil bath air cleaner is probably the best for tractors in dusty conditions. The dirt will clog the paper filter pretty fast which means some cost in replacing the filter. The foam pre-filter will also get dirty fast and require cleaning, probably more than the oil bath filter. The oil bath filter just requires some maintenance about every 10 hours of use, longer if not dusty. If you do a search of the archives you'll find some posts about the subject.
Stephen Foster
PostPosted: Sun Aug 30, 2009 9:44 pm    Post subject: Re: Looking for better air filter for 54 Ford NAA Tractor. Reply to specific post Reply with quote
Has anyone tried the Harco prefilter for your tractor. don't know what it dose really can anyone explain? I just got my first 8n running. It has the basic oil bath air filter. was kinda wondering if there was any better filter or should i just stick with what it has?
MarkB_MI
PostPosted: Mon Aug 31, 2009 2:09 am    Post subject: Re: Looking for better air filter for 54 Ford NAA Tractor. Reply to specific post Reply with quote
You really can't improve on the original oil bath air cleaner. For many years you could order an optional "heavy duty" air cleaner for your pickup. It was oil bath, while the standard cleaner was paper.
Dry filters are more environmentally friendly and easier to service, but don't clean the air any better. One problem with dry filters is that you tend to get a bit of dust in the intake every time you service them, which is why most heavy equipment has a service indicator so you don't service the filter any more often than necessary.
Dean
PostPosted: Mon Aug 31, 2009 3:35 am    Post subject: Re: Looking for better air filter for 54 Ford NAA Tractor. Reply to specific post Reply with quote
733:
I agree with the earlier posters. You cannot cost effectively improve on your oil bath air filter. Oil bath air filters were discontinued because paper filters were less expensive not because they performed less well.
That said: Like a paper filter, if your oil bath filter has not been properly maintained it may be highly restrictive resulting in excessive fuel consumption, reduced power and eventually premature engine wear. Verify that the mesh filtering elements are clean and the internal air tube is not restricted with accumulated material.
Dean
souNdguy
PostPosted: Mon Aug 31, 2009 10:38 am    Post subject: Re: Looking for better air filter for 54 Ford NAA Tractor. Reply to specific post Reply with quote
I agree with the others.. at most.. I'd get a precleaner / snorkel/settler jar/topper and clean it and service the oil frequently, and clean the mesh as needed.
these tractors didn't like 55+ years because they had bad air cleaner technology...
soundguy
