| Author |
Message |
Ray Mayers New User
Posted: Mon Nov 02, 2009 2:33 pm Post subject: Where do I purchase an oil filter for a john deere 70 diesel |
Where do I purchase an oil filter for a john deere 70 diesel tractor?Thanks, Ray Mayers. |
| Back to top |
4010 puller Long Time User
Posted: Mon Nov 02, 2009 2:51 pm Post subject: Re: Where do I purchase an oil filter for a john deere 70... |
At the JD dealer or any wix dealer, fleetguard, baldwin, napa etc. Go to any of their websites and lookup the part number |
| Back to top |
buck eye al Guest
Posted: Mon Nov 02, 2009 3:02 pm Post subject: Re: Where do I purchase an oil filter for a john deere 70... |
Deere will likely have the best price on the filter. At least that's how it is here in western Ohio.
If however you go to a NAPA store or Tractor Supply, they will have one but it will also come with a new seal which does not come with the Deere filter!
Sorta therefore depends on what you want or need.
The seals seldom NEED replacement and if you decide to replace it you'll do some pickin to get 'er all out but I'm guessing you're not real familiar with all this or you'd not have asked the question. That assumption leads me to offer an extra word of caution!
Don't assume that big nut needs tightened real tight! It does NOT. You can make a LOT of work for yourself real quick if you tighten it as much as its size might lead you to think necessary. Tighten only enough to not leak. A 6" adjustable wrench would usually be sufficient if they'd fit the nut. |
| Back to top |
buickanddeere Tractor Guru
Joined: 31 May 2003 Posts: 23633 Location: in front of computer
Posted: Mon Nov 02, 2009 3:09 pm Post subject: Re: Where do I purchase an oil filter for a john deere 70... |
You can purchase JD parts at a JD dealer.1-800-522-7448 for info |
| Back to top |
Ray Mayers New User
Posted: Mon Nov 02, 2009 3:32 pm Post subject: Re: Where do I purchase an oil filter for a john deere 70... |
Thank you very much for your reply. I just purchased the tractor and it runs very good.I would appreciate any info on maintainance.My be a stupid question, but where do you add the motor oil?There is a cap on top the block and the dip stick is toward the bottom.Thanks, Ray. |
| Back to top |
James Howell Tractor Guru
Joined: 06 Mar 2006 Posts: 5619 Location: Hutchins, TX
Posted: Mon Nov 02, 2009 3:50 pm Post subject: Re: Where do I purchase an oil filter for a john deere 70... |
Created a lubrication checklist of each of our tractors.
Have a lubrication checklist for "Big John" our '55 model 70 diesel tractor.
Lubrication checklist was created from information from an original JD Model 70 Diesel operator's manual.
Checklist has lubrication locations, wrench sizes for our tractor, and quantity/capacity recommendations.
Also has the JD filter part number and TSC filter part number.
Send me an email if you would like this lubrication checklist. |
| Back to top |
Posted: Mon Nov 02, 2009 3:51 pm Post subject: Re: Where do I purchase an oil filter for a john deere 70... |
Sorry about that; email in now open. |
| Back to top |
mjbrown Guest
Posted: Mon Nov 02, 2009 5:46 pm Post subject: Re: Where do I purchase an oil filter for a john deere 70... |
The oil fill in above and in front of the belt pulley on top of the case. If you go to a Deere dealer to get a filter get an operators manual. |
| Back to top |
Freddy Long Time User
Posted: Mon Nov 02, 2009 7:01 pm Post subject: Re: Where do I purchase an oil filter for a john deere 70... |
go to O'Reilly's and get a WIX filter P/N 51252. American made and comes with a new bowl seal. NOT Mexican like JD and you still have to buy the seal separate. |
| Back to top |
| Back to top |
Posted: Mon Nov 02, 2009 7:03 pm Post subject: Re: Where do I purchase an oil filter for a john deere 70... |
I am not all there today P/n 51242 |
| Back to top |
F-I-T Tractor Guru
Joined: 27 Feb 2002 Posts: 8447 Location: United States
Posted: Tue Nov 03, 2009 7:22 am Post subject: Re: Where do I purchase an oil filter for a john deere 70... |
Remember to tell him to drain the timing cover, too. It's pretty tough to describe all of the drain points and thingys on a 70D if you don't have an operator's manual in hand. People start adding motor oil to the FRG because the lettered series used motor oil, they crank the dip stick tight to check the level when it it is supposed to just rest on the top of the threads, drain the pony AFTER they added fresh oil to the diesel crankcase. Unless you've been around one, it really takes an hour of manual stud to make certain that you do things right and in the correct order. |
| Back to top |
