help!!! want start, 9n ford
bouis
PostPosted: Tue Nov 10, 2009 1:08 pm    Post subject: help!!! want start, 9n ford Reply to specific post Reply with quote
i have a 9n ford. i changed it over to 12v system complete(12v alternator,12v coil,electronic ignition kit and all new wiring). got it running great. have 2 hrs max on run time and now will not start. i have 12v to the coil. no spark at the plugs.has to be the coil or electronic ign. parts. how do i test to see which one is the problem?
thanks
Bruce (VA)
PostPosted: Tue Nov 10, 2009 2:47 pm    Post subject: Re: help!!! want start, 9n ford Reply to specific post Reply with quote
I can help you w/ part of your problem.
Coil problems are difficult to diagnose. For starters, round coils are pretty robust & square coils aren’t (because of the difference in insulation used), but neither one will hold up to a poorly done 12v conversion that allows too much current to the coil. Too much current creates heat which melts the insulation. There are a few ways to see if a coil is bad, but it’s not possible to determine if a coil is good w/o some expensive testing equipment. If you detect a dead short or high resistance in the coil w/ an ohm meter, it’s bad. If it’s cracked, it’s bad. If a sidemount coil w/ battery voltage to the primary will not jump a ¼” gap from the secondary wire to the block, it’s bad. But, here is the hard part: even if you do not detect a short, even if it will produce a spark, even if it’s not cracked, that doesn’t mean the coil will work when it’s hot & under a load. So, it’s a process of elimination. If the tractor starts & runs fine for 30 minutes or an hour then cuts off & refuses to re-start, and you checked for spark at the plugs & it had no spark at all, AND you have the correct voltage at the coil that’s a good sign that you have a bad coil. Let it cool off, restart it & if you have a good spark, odds are it’s a bad coil. But, even then, you might end up w/ a spare coil on the shelf!
So, three questions.
What resistors are you using? You could have too much resistance.....or not enough resulting in a melted coil. (as well as an EI if you left the key on)
Next, what EI kit did you use? Troubleshooting is different based upon the make.
Finally, are you sure the battery is fully charged? The EI does not like low battery voltage.
That's as far as my abilities allow me to go troubleshooting an EI. I've never seen a need to convert any of my 4 N's to 12v, much less add EI, so I can't help w/ that. But, other folks around here do have EI's; I'm sure they will be along to help out.
50 Tips
HCooke
PostPosted: Tue Nov 10, 2009 3:39 pm    Post subject: Re: help!!! want start, 9n ford Reply to specific post Reply with quote
If you kept the points you could remove the EI and reinstall them, If it runs then your new EI is not working.
bouis
PostPosted: Wed Nov 11, 2009 1:44 pm    Post subject: Re: help!!! want start, 9n ford Reply to specific post Reply with quote
thanks for the info
