1953 golden jubilee wiring
ken hunter
PostPosted: Fri Jan 01, 2010 4:24 am    Post subject: 1953 golden jubilee wiring Reply to specific post Reply with quote
need help with the wiring for a 53 ford golden jubilee. i need a good wiring diagram of the whole electrial system. also need to know how the head light clips lock in place to hold the lights. thanks ken hunter
Web Dawg
PostPosted: Fri Jan 01, 2010 6:00 am    Post subject: Re: 1953 golden jubilee wiring Reply to specific post Reply with quote
6v
Untitled URL Link
ken hunter
PostPosted: Fri Jan 01, 2010 6:29 am    Post subject: Re: 1953 golden jubilee wiring Reply to specific post Reply with quote
i have a two wire generator f and g where does the a wire go from the regulator to the generator.the ford dealer told me i have the right generator for this tractor.
Web Dawg
PostPosted: Fri Jan 01, 2010 7:09 am    Post subject: Re: 1953 golden jubilee wiring Reply to specific post Reply with quote
These 6v and 12 v systems are all I can find.
awhtx
PostPosted: Fri Jan 01, 2010 7:12 am    Post subject: Re: 1953 golden jubilee wiring Reply to specific post Reply with quote
There should be a larger stud on the rear endplate of the gen marked A for Armature. A large wire runs from this stud to the Armature terminal on the regulator. The wire on the small stud marked F goes to the Field terminal on the regulator. The wire on the small stud marked G goes to one of the hold down screws that attaches the regulator to the steering column for a Ground.
petra79
PostPosted: Fri Jan 01, 2010 7:25 am    Post subject: Re: 1953 golden jubilee wiring Reply to specific post Reply with quote
If the dealer said you have the correct gen. maybe ask them for a copy of their diagram.
JMOR
PostPosted: Fri Jan 01, 2010 9:02 am    Post subject: Re: 1953 golden jubilee wiring Reply to specific post Reply with quote
petra79 wrote:
(quoted from post at 11:25:40 01/01/10) If the dealer said you have the correct gen. maybe ask them for a copy of their diagram.
Three terminals, like this:
AND this color:
ken hunter
PostPosted: Sun Jan 03, 2010 6:56 am    Post subject: Re: 1953 golden jubilee wiring Reply to specific post Reply with quote
i dont know if i have the right generator the ford dealer told me it is but i have only 2 terminals f and g there is no terminal on the back for terminal a to the voltage regulator how does that work im lost now
JMOR
PostPosted: Sun Jan 03, 2010 9:48 am    Post subject: Re: 1953 golden jubilee wiring Reply to specific post Reply with quote
ken hunter wrote:
(quoted from post at 10:56:40 01/03/10) i dont know if i have the right generator the ford dealer told me it is but i have only 2 terminals f and g there is no terminal on the back for terminal a to the voltage regulator how does that work im lost now
Ken, it can not work without an ARM terminal, as that is the generator's output. NOW, if you really only have 2 terminals, they are very likely FIELD and ARMATURE, without a Ground terminal (rely on mounting bolts). What that says to me is the it is not the factory original generator for your tractor. Now, that doesn't mean it can't be made to work, but for most of us to provide assistance we need to know what the generator is. Any numbers, ID, photos, etc. may be helpful, or if you can find a 'real' generator repair shop (that isn't Auto Zone, O'Really's, CarQuest, etc.) they might ID it for you & even tell you if it works, & what specific regulator you need to use with it.
ken hunter
PostPosted: Mon Jan 04, 2010 3:06 am    Post subject: Re: 1953 golden jubilee wiring Reply to specific post Reply with quote
i think you are right i have a generator shop in town been their before. ill take the generator case with me today and have them look at it again ill let you know what happen when i get back
ken hunter
PostPosted: Fri Jan 08, 2010 5:09 am    Post subject: Re: 1953 golden jubilee wiring Reply to specific post Reply with quote
the generator is a delco 2 terminal one wire field and one armature the case is ground. the generator and starter shop here told me some are 2 and some others are 3 terminal it will still work out ok for me.i thought i had the wrong generator thanks ken
JMOR
PostPosted: Sat Jan 09, 2010 12:46 am    Post subject: Re: 1953 golden jubilee wiring Reply to specific post Reply with quote
ken hunter wrote:
(quoted from post at 09:09:10 01/08/10) the generator is a delco 2 terminal one wire field and one armature the case is ground. the generator and starter shop here told me some are 2 and some others are 3 terminal it will still work out ok for me.i thought i had the wrong generator thanks ken
Rather than a stud terminal, some Delco units had a tapped hole in the barrel for a screw to attach a ground wire.
