3000 Clutch/Axle PIn Job Complet
Hobo,NC
PostPosted: Sun Feb 07, 2010 6:36 pm    Post subject: 3000 Clutch/Axle PIn Job Complet Reply to specific post Reply with quote
Been planing on clutching and doing some other maintenance for a year,,, planed completion date Feb 1 2010,,, did not start till Feb 2 2010,,, took Feb 3 2010 off to go to the southern farm show.
Cool Ran into a problem I ordered a 15 spline clutch kit so to save on return ship'n I ordered a 10 spline main drive disc,,, gonna return the 15 spline,,,
I did not have a clutch line up too for a 10 spline (15 spline does not work on a 10 spline so I made one out of steel (took a slow learner 2 1/2 hours) the more I thought about it I could have turned the the 15 spline down to work but I never liked the plastic tool to begin with,,, I read the manual and it stated if a if a button clutch was to be installed the long hub protrusion must face the flywheel (it had a button clutch),,, if a organic lined disc is to be used the long hub must face the double clutch,,, I used the organic so installed the long part of the hub to the DC,,, I measured it all out and could not see were it would make a difference Rolling Eyes Clutch job went OK...
While I was their I replaced the rear crank seal,,, I first made a tool out of a PVC conector,,, then found a piece of steel i could turn out and add a step so not to install the seal to deep and made a plate to run the installer in,,, worked good,,, took 2 hour's are so to make it...
I also replaced the front axle pin and bushing,,, the pin fought me the hole dang way,,, what a beach to remove,,, took lots of heat,,, I had no problem installing the new pin go figger... this 3000 has a 1 3/4" axle pin and a 2" center axle pin bushing,,, it has a spacer to make up the difference,,, while I had a mess on the lathe turned out a new spacer,,, BYW the spacer sells for $73 from CNH,,, add another hour to the job,,, before I paid $73 I would reuse the old spacer... I also made a remover to knock out the old bushing and boarded a washer to fit the remover to convert it to a installer...
engine bolted up,,, axle installed,,, added a new water pump and hoses,,, installed the new radiator,,, aftermarket Radiator fits nice just had to tap for the shroud screws... installed tin and added a new muffler..
got a few questions
1) could not get the hydraulic tube suction to pull out of the rear housing so let it along,,, how does that bugger come out... was gonna replace the o-ring,,, soon I am going to remove the lift cover and will take a look then
2) Haft way tightened the new muffler on the manifold pipe (vertical) with a standard muffler clamp,,, would like to have a nice band clamp instead of a ugly muff clamp right were I can see it,,, mite have to make it Idea
Next I need to rebuild the loader frame,,, pull the lift cover and change out the fluids,,, I had all new bolts on hand for the axle rebuild,,, it needed them bad,,, a loader sure works on'em Wink here's a few pix...
[img]
[/img]
[img][/img]
Brian Allen
PostPosted: Mon Feb 08, 2010 8:43 am    Post subject: Re: 3000 Clutch/Axle PIn Job Complet Reply to specific post Reply with quote
Hobo
It looks to me that you are doing a great job.
New clutch discs usually indicate "flywheel side"
Keep up the good work; and "keep the pictures comin"!
I wish I had a lathe, to get some of the easy stuff turned up.
I guess I'll have to watch the auctions after I get moved.
Brian
View user's profile AIM Address Yahoo Messenger
Hobo,NC
PostPosted: Mon Feb 08, 2010 10:35 am    Post subject: Re: 3000 Clutch/Axle PIn Job Complet Reply to specific post Reply with quote
Brian Allen wrote:
(quoted from post at 17:43:03 02/08/10) Hobo
Brian
no marking,,, normally they are marked because of a interference issue,,, not the case here as it can be installed either way so just went by the manual,,, Gonna have to put a fender in front of the lathe,,, I am fender broke and need something to lay my belly on...
Hobo,NC
PostPosted: Mon Feb 08, 2010 6:54 pm    Post subject: Re: 3000 Clutch/Axle PIn Job Complet Reply to specific post Reply with quote
Got the foot feed installed on the 3000 tonite,,, got it from Bill Crafton,,, its not bad at all,,, started out having to do some re-engineering till I figged out it needed a spacer under the mount were it bolts up to the steering gear DUH!,,, then all went well after I cleaned all the paint off the work'n ends, re drilled the cotter pin holes and filed down the ends to fit thru the pivot hole real nice,,, I did have to drill the hole out a tad larger were it fits the original hand throttle leaver... I had to come up with a few nuts and bolts BTW are metric but no problem,,, I also had to improvise a throttle spring cuzz it does not come with one,,, drilled a 3/8"
nut and tapped for a 1/4" NF bolt so I would have something to add the spring to and to also adjust the spring tension to my like'n,,, none of this was a problem for me cuzz I had all the extra parts need on hand,,, would be nice if they came with the foot feed Wink.... I am gonna have to move the seat back a tad,,, its all the way back and was not to my like'n before the foot feed,,, also need to add something to raise my foot a tad so the foot feed will feel more natural,,, I think once i get the spring tension to my like'n i will like it Smile I also think the steering gear covers will fit with a slight cut for the throttle rod,,, its already somewhat cut for this but needs a little more,,, I don't think I am going to put them back on anyways cuzz they only make a nice mouse bed and trap junk...
[img]
[/img]
[img][/img]
Brian Allen
PostPosted: Tue Feb 09, 2010 6:41 am    Post subject: Re: 3000 Clutch/Axle PIn Job Complet Reply to specific post Reply with quote
Hobo
Thanks for the foot feed pictures.
Looks like a decent fit too.
Maybe I can find time to install mine someday; if I can still find it.
Can you get a picture of your version of that spring?
Thanks again.
Brian
Hobo,NC
PostPosted: Tue Feb 09, 2010 9:50 am    Post subject: Re: 3000 Clutch/Axle PIn Job Complet Reply to specific post Reply with quote
Brian Allen wrote:
(quoted from post at 15:41:14 02/09/10) Hobo
Thanks again.
Brian
Its their marked in yeller just for you Very Happy ,,, If its the same one I got from Bill I will work up a list of parts you will need to do the install...
Brian Allen
PostPosted: Tue Feb 09, 2010 9:58 am    Post subject: Re: 3000 Clutch/Axle PIn Job Complet Reply to specific post Reply with quote
Hobo
OK, I guess I'll just plead ignorance, cause I did not notice it the first time I looked! I think I have a spring about that size too.
I would appreciate the list too!
Brian
Brian Allen
PostPosted: Tue Feb 09, 2010 10:06 am    Post subject: Re: 3000 Clutch/Axle PIn Job Complet Reply to specific post Reply with quote
Hobo
I forgot to mention:
My 3000 Ford's vertical muffler just just sits on the pipe extension.
It does turn every now and then, miss-aligning the rain cap, but I try not to look at it , maybe some day I'll try to find a pretty clamp to attach it permanent.
I have noticed a hex screw keeping the muffler from moving on several other tractors. It does look better than a muffler clamp.
Brian
Hobo,NC
PostPosted: Tue Feb 09, 2010 7:03 pm    Post subject: Re: 3000 Clutch/Axle PIn Job Complet Reply to specific post Reply with quote
Brian Allen wrote:
(quoted from post at 19:06:59 02/09/10) Hobo
Brian
Mite have to remove the muff clamp,,, but first gonna make some kind of band clamp...
Mount foot feed to floor board
2) 5/16X1 1/4 bolts NF or NC your call
2) 5/16 nuts NF/NC your call
2) 5/16 lock washers
2) 5/16 flat washers
2) 3/8 nuts used for spacer tween foot feed and Flore board
pivot to steering gear spacer
1) 1/2" lock washer
throttle rod
4) 5/16 nuts NF
Throttle spring holder (adjustable)
1) 3/8 nut
1) 1/4" bolt 1/2" long (mite get a 3/4" just in case)
drill and tap the 3/8" nut for the 1/4" bolt to nail the nut to the throttle rod and so you can adjust the spring Wink
1) 1/16" X 1" are longer cotter pin for the throttle rod near the carb
2) 3/32 cotter pins for the pivot and to the foot feed rods
little gismo with the chain to work the hand throttle
1) 6MX10MX1.0 are longer say 15MM
Foot feed rod jam nut to pivot
1) 6MMX1.0 nut
I had to drill out the end that goes on the original hand throttle to 21/64,,, had to remove the spring clip drill and file,,, measure yours if it does not fit,,, nut'n to removing the clip just don't let it fly away
I wasted rite much time re-engineering the damm thang till it hit me its was cocky eyed and a spacer under the pivot would cure the whole deal,,, then had to do some chiffering till it hit me it needed a spring to return the carb to idle and give some feel to the foot feed...
My 3000 will not start if the throttle is off idle,,, may be mine are may be they all are like that dunno... I may buy another just for the ell of it to see if I can make it work on my 850 and a N...
Brian Allen
PostPosted: Wed Feb 10, 2010 10:26 am    Post subject: Re: 3000 Clutch/Axle PIn Job Complet Reply to specific post Reply with quote
Hobo
Thanks for the list!
I'll save it, so I'll have it when I get started on the foot feed.
Brian
Greg Wolodkin
PostPosted: Sun Mar 20, 2011 8:26 pm    Post subject: Re: 3000 Clutch/Axle PIn Job Complet Reply to specific post Reply with quote
My parts manual shows a muffler clamp on the US version, and a solid one-piece connection from manifold to muffler on the UK version.
I've got my vertical exhaust with no clamp now and it's an OK fit but it does leak just a little especially at startup. I didn't want to put a soon-to-be-rusty muffler clamp up there either..
Greg
