1949 CASE DC Oil Specs
Ben Holland
PostPosted: Sun Mar 07, 2010 7:15 pm    Post subject: 1949 CASE DC Oil Specs Reply to specific post Reply with quote
Does anyone know the oil specs on 1949 Case DC and about how much is needed? Engine, Transmission, Rear End, Hydraulics and anything else you could think of. Thanks
olgentdc
PostPosted: Sun Mar 07, 2010 7:34 pm    Post subject: Re: 1949 CASE DC Oil Specs Reply to specific post Reply with quote
engine 2 gallon 40 wt. ,Hot & Hard summer work 50 wt.. Also drain wet hand clutch housing ...Tranny reqires around 12 gallon 90 weight , fill to 1/4 pipe plug found on tranny ,,hydro 10 or 30 weight , 10 quarts
Tom Railsback
PostPosted: Sun Mar 07, 2010 7:42 pm    Post subject: Re: 1949 CASE DC Oil Specs Reply to specific post Reply with quote
Capacities:
Crankcase--1.75 gallons (7 quarts)
Transmission--10.5 gallons (42 quarts
Cooling System--6.75 gallons (27 quarts)
Hydraulics--9 to 11 quarts depending on cylinder
used
Oil types:
Crankcase--90 degrees and above--SAE 30
32 to 90 degrees--SAE 20
10 to 32 degrees--SAE 10
below 10 degrees--SAE 10W
Transmission--Below 32--SAE 90, above 32--SAE
140
Hydraulics--same as engine
These specifications are taken from an original dealer's service manual.
