Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
1950 8N hesitates and backfires
Post new topic    Yesterday's Tractors Forum Index -> Restoration and Repair Tips
Steve's Fords
PostPosted: Thu Mar 18, 2010 6:31 am    Post subject: 1950 8N hesitates and backfires Reply to specific post Reply with quote
Hi, I have a 1950 8N thats been sitting under my barn for 4 years. Decided to get it running and sell it. Ran fine when parked. Wouldnt start, so....replaced the battery, cleaned all electrical connections, replaced cap rotor,points, condenser, coil, plugs, drained gas, cleaned sediment bowl, had carb off several times and cleaned, replaced gaskets. Got it started, got it charging, but runs rough, hesitates, backfires, engine bogs a little when you turn the lights on, trying to adjust the carb is no help. Just had the front mount dist off again and noticed th tangs on the back where it fits into the crank look worn, like the dist may have been loose at one time, crank looks ok. any ideas? This ones got me. Thanks, Steve
old
PostPosted: Thu Mar 18, 2010 11:47 am    Post subject: Re: 1950 8N hesitates and backfires Reply to specific post Reply with quote
What are you setting the points at??? Since it is a front mount the points need to be set at 0.015 and if you misread the manual and set them at 0.025 like for the side mounts they will not run well. Next will it still run if you pull the main jet adjustment screw all the way out?? If it does then your carb still need work
Steve's Fords
PostPosted: Thu Mar 18, 2010 12:45 pm    Post subject: Re: 1950 8N hesitates and backfires Reply to specific post Reply with quote
Hi, Yes I set them at 15, and when I turn the jet the motor bogs down more and stalls???
old
PostPosted: Thu Mar 18, 2010 2:20 pm    Post subject: Re: 1950 8N hesitates and backfires Reply to specific post Reply with quote
Is that turning it in or turning it out?? Do you get black smoke as you turn it out??
Steve's Fords
PostPosted: Fri Mar 19, 2010 6:34 am    Post subject: Re: 1950 8N hesitates and backfires Reply to specific post Reply with quote
[quote="old"](reply to post at 15:20:49 03/18/10) [/quoteHi, Turning it either way, seems to take several turns to make a differance. Went to start this morning, wanted to catch but didnt, and I noticed gas flowing fron the carb.
Jerry/MT
PostPosted: Fri Mar 19, 2010 9:48 am    Post subject: Re: 1950 8N hesitates and backfires Reply to specific post Reply with quote
Either you flooded it by over choking or the float valve isn"t closing. Sometimes the float hangs and rapping it with a block of wood will get it to un-hang. Check your spark. Should be fat and bluish white, the color of lightning. if you have a good spark, check the timing( it pretty hard to mis-time a front mount as I understand it) and if that is good, the problems in the fuel system (dirty carb, misadjusted, etc).
Steve's Fords
PostPosted: Fri Mar 19, 2010 10:00 am    Post subject: Re: 1950 8N hesitates and backfires Reply to specific post Reply with quote
Hi, Checking spark now, then will pull carb again, will check spark and advise.
Steve's Fords
PostPosted: Fri Mar 19, 2010 11:44 am    Post subject: Re: 1950 8N hesitates and backfires Reply to specific post Reply with quote
Just pulled a plug, very little spark, will try setting timing again, I think the dist tang being worn may be the problem. wondering if the ignition switch may be a factor, key feels loose.
Jerry/MT
PostPosted: Fri Mar 19, 2010 4:38 pm    Post subject: Re: 1950 8N hesitates and backfires Reply to specific post Reply with quote
Timing doesn"t cause a weak spark, misadjusted points do. Check the point adjustment and then run through the primary electrical circuit to see if you are getting low voltage to the coil.
