Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
IH 47 baler knotter problems
Goto page 1, 2  Next
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley
Lew Best
PostPosted: Mon Apr 12, 2010 8:04 pm    Post subject: IH 47 baler knotter problems Reply to specific post Reply with quote
Hey guys
I finally got my 47 going kinda. This is one of a pair (46 & 47) I traded for a while back. One had a broken needle; other a bent needle. I used the good needles on this one. These are the first twine balers I've messed with; most folks around here use wire balers. I do like the idea of twine (40 bux a bundle compared to 70 per roll for wire) from a cost standpoint tho so decided to give them a try. They'd been sitting for about 5 years the guy said. Tying problems don't surprise me they've been sitting so long but I need some guidance.
I picked up some old hay I'd cut & raked back in the fall when my wire baler quit (JD 214WS) & here's what happened.
http://img.photobucket.com/albums/v707/lewbest/balers/twinetop01.jpg
At top behind the knotter mechanism
http://img.photobucket.com/albums/v707/lewbest/balers/knotterleft.jpg
Left knotter
http://img.photobucket.com/albums/v707/lewbest/balers/knotterright.jpg
Right knotter
This is old twine (which I've seen recommendations against) but it isn't breaking before it gets to the needles. I'd prefer not to buy twine until I have an idea whether the baler's going to work but will if this is a "probable cause" of my problems.
Any help appreciated!
Lew near Waco, TX
showcrop
PostPosted: Tue Apr 13, 2010 3:54 am    Post subject: Re: IH 47 baler knotter problems Reply to specific post Reply with quote
Trying to test a baler with old twine is probably not a good use of your time.
Lew Best
PostPosted: Tue Apr 13, 2010 4:33 am    Post subject: Re: IH 47 baler knotter problems Reply to specific post Reply with quote
Thanks; I think I'll call around & see if anyone has any twine today. Twine balers are scarce in this area, mostly wire. I'm pretty sure TSC can order it but that'll take a few days to get. I had to buy hay the last couple of winters & out of about a dozen different sources (hay was scarce; had to do lotsa "shopping") I only got twine tied bales from one source; all the rest were wire tied.
Lew
tomturkey
PostPosted: Tue Apr 13, 2010 4:51 am    Post subject: Re: IH 47 baler knotter problems Reply to specific post Reply with quote
My son and I picked-up a 47 last year. We only used it once. It missed about every fifth bale. I bought a book from binderbooks and we will be going thru the timing, set-up, clearance specs page by page. I've read thru the book/manual. It lays out a step by step process on getting them set correctly. gobble
dboll
PostPosted: Tue Apr 13, 2010 5:02 am    Post subject: Re: IH 47 baler knotter problems Reply to specific post Reply with quote
1 out of five? thats pretty good! we fought our 37 from new and finally traded it on a 425, we had a good knotter man who would get it tying good for 1000 or 1500 bales then the problems would begin again, our neighbor had a 47 that tied better but I wouldn't get my hopes too high.
Lew Best
PostPosted: Tue Apr 13, 2010 5:19 am    Post subject: Re: IH 47 baler knotter problems Reply to specific post Reply with quote
tomturkey wrote:
(quoted from post at 07:51:54 04/13/10) My son and I picked-up a 47 last year. We only used it once. It missed about every fifth bale. I bought a book from binderbooks and we will be going thru the timing, set-up, clearance specs page by page. I've read thru the book/manual. It lays out a step by step process on getting them set correctly. gobble
I have the manual & went through the timing but did not try adjusting anything on the knotters. It had a broken needle I replaced & I adjusted the needles per the book. I thought that since the knotters were probably working ok when it broke the needle I'd be better off trying them "as set" first since I don't know what I'm doing.
Lew
jhilyer
PostPosted: Tue Apr 13, 2010 6:34 am    Post subject: Re: IH 47 baler knotter problems Reply to specific post Reply with quote
The problem with your IH 47 is that it's an IH 47.
I struggled with one for years, then got a New Holland. Magically, my trouble went away.
Good luck.
Lew Best
PostPosted: Tue Apr 13, 2010 7:10 am    Post subject: Re: IH 47 baler knotter problems Reply to specific post Reply with quote
If I can get this one working fairly well I may look for a NH if I like twine tied bales. Wire is so high but by far the most common around here. At an auction I frequent you'll find wire balers about 10 to one over twine balers. Those twine bales I bought over the winter were far looser (harder to handle by far) than wire tied bales. NH seem to be popular; they must support them better than their skid steers. I have a NH skid steer built in the '80's & most parts are obsolete already; I hafta rely on "old stuff" (mostly 60's-70's) due to price. I just have a little hobby farm; cut & bale about 3 acres to feed my miniature donkeys.
Lew
Nebraska Cowman
PostPosted: Tue Apr 13, 2010 7:43 am    Post subject: Re: IH 47 baler knotter problems Reply to specific post Reply with quote
The way an IH knotter works is the hay exiting pulls the knot off the bill hook. If the twine is weak it will break before releasing. There is an adjustment on bill hook tension but if it is too loose it won't tie either. So yes, get everything cleaned up. The bill hooks better be shiny bright, and have good heavy twine, The 8000 ft works better than 10,000
Lew Best
PostPosted: Tue Apr 13, 2010 8:34 am    Post subject: Re: IH 47 baler knotter problems Reply to specific post Reply with quote
Thanks; I just ran it a bit more after cutting away all that twine on the one knotter; it seems to be doing fine now. the other one is tieing but not cutting after it ties; gotta check the knife on it but first I gotta fix a flat on a front tractor tire; guess I ran over an old mesquite branch yesterday. Was flat this morning; aired it up & it held for bout 30 minutes. Sad Always something it seems.
Lew
dboll
PostPosted: Tue Apr 13, 2010 12:01 pm    Post subject: Re: IH 47 baler knotter problems Reply to specific post Reply with quote
if the twine has been kept dry and has no deterioration it is just fine
Lew Best
PostPosted: Tue Apr 13, 2010 12:31 pm    Post subject: Re: IH 47 baler knotter problems Reply to specific post Reply with quote
it don't look that bad but does have some discolored spots (I'm guessng where the bottom of the roll is dark?) as it sat in the baler for bout 5 years I'm told. I called around; none of the farm stores/eq dealers stock natural twine; only bout half of them here have plastic for square balers but good old TSC ordered me some; should be here in bout a week.
Lew
flying belgian
PostPosted: Tue Apr 13, 2010 4:54 pm    Post subject: Re: IH 47 baler knotter problems Reply to specific post Reply with quote
one out of five is considered good for an IH baler. It is working like it should so don't mess with it.
parisspringstom
PostPosted: Wed Apr 14, 2010 6:07 pm    Post subject: Re: IH 47 baler knotter problems Reply to specific post Reply with quote
I ran a 46 for years and fought the knotter every year. The first batch I baled had to oil it well all over to get it working and then it would go to tying. It would miss one now and then in the best of circumstances. Bought a New Holland 68 for scrap price that had been sitting outside for years. Replaced the rusted springs and oiled and lubricated the baler well and it has only missed when the string ran out in two years. Other than the fact that I cannot put as much hay thru the 46 as the NH 68 it probably is a good bailer but you have to know more about it and how to keep it set right.
Lew Best
PostPosted: Wed Apr 14, 2010 6:20 pm    Post subject: Re: IH 47 baler knotter problems Reply to specific post Reply with quote
Yeah it's gonna be a learning process I'm sure. I'm anxious for the new twine to come in & for it to dry up a bit (we're predicted to get rain for the next few days but I'm not complaining; it"s gotten really dry here again) so I can try tinkering with it a bit more.
Lew
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley All times are GMT - 8 Hours
Goto page 1, 2  Next
Page 1 of 2
