Author |
Message |
Woodchuck Regular
Posted: Thu May 06, 2010 7:32 am Post subject: Sherman Transmission Install |
Does this site sell the transmission front seal? I looked in the parts pages and couldn't find it.
I hope to start installing my Sherman this weekend and want to make sure I have all the parts. |
Back to top |
Ken-Pa Long Time User
Posted: Thu May 06, 2010 7:40 am Post subject: Re: Sherman Transmission Install |
Hey Woodchuck, check with John Smiths site .He can direct you if he doesn't have it .HTH! God bless |
Back to top |
souNdguy Tractor Guru
Posted: Thu May 06, 2010 7:49 am Post subject: Re: Sherman Transmission Install |
should be same front seal as an N, as a sherman replaces the input shaft..
soundguy |
Back to top |
Dell (WA) Tractor Guru
Posted: Thu May 06, 2010 7:54 am Post subject: Re: Sherman Transmission Install |
Woody......yep, YT does sell the tranny front seal that fits the Sherman input shaft.
Oil Seal, Main Drive Gear - Oil Seal For 3 & 4 Speed transmission Main Drive Gear on: 9N, 2N, 8N, 600, 700, 800, 900, NAA, NAB, Jubilee. **Minimum order qty is 2** (Part No: 8N7052A) .......$3.06 ea (cheap)
Sherman uses the same seal as the regular 3&4 speed trannys. ......Dell
Back to top |
Bob Tractor Guru
Posted: Thu May 06, 2010 8:55 am Post subject: Re: Sherman Transmission Install |
It's GOOD to support this site! HOWEVER, for ONE small part like that seal the shipping will probably eat you alive.
Go to a local auto parts store or industrial "bearings and drives"-type supplier and ask for a SKF (C/R) # 13568 or a National or Timken # 480570.
If they have it in stock or can get it on a stock order in a day or two you MAY not have to pay freight.
The NH part # is 8N7052A2, about $8 at the local NH dealer, but they don't stock it.
The nearby Deere dealer even has it in stock (for about $12) under DEERE part # AH21815. That's kinda pricey but MIGHT still be cheaper than ordering and paying freight. |
Back to top |
Greg 2N (TX) Regular
Posted: Thu May 06, 2010 9:59 am Post subject: Re: Sherman Transmission Install |
Woodchuck,
Did you happen to rebuild your Sherman?
Just wondering how it went if you did, I'm about to rebuild mine.
Greg |
Back to top |
ron8 Guest
Posted: Thu May 06, 2010 8:16 pm Post subject: Re: Sherman Transmission Install |
for sherman parts, go to,, buckies@aol.com |
Back to top |
Woodchuck Regular
Posted: Fri May 07, 2010 3:03 am Post subject: Re: Sherman Transmission Install |
Thanks Dell and Bob!
I ordered a clutch kit and a new exhaust so the shipping isn't to bad. $19.00 on the whole order.
I got my Sherman combo from Jim Bills, a member of this site, who rebuilds them.
I've had it about a year and a half and am just getting around to installing it.
Thanks, again! |
Back to top |
jimNCal Tractor Expert
Joined: 06 Oct 2003 Posts: 1842 Location: Fresno, Calif
Posted: Fri May 07, 2010 7:17 am Post subject: Re: Sherman Transmission Install |
Chuck,
You shouldn't have needed to order that seal. I always replace that seal when I go thru a Sherman. Did I miss one or do a bad job of it? |
Back to top |
Woodchuck Regular
Posted: Fri May 07, 2010 11:54 am Post subject: Re: Sherman Transmission Install |
Jim,
It's been so long since I got the Sherman from you I didn't even look.
I guess now I have to get another N so I can use up the extra.
The wife will be so happy! |
Back to top |
rfuchs New User
Posted: Tue May 15, 2012 1:39 pm Post subject: Re: Sherman Transmission Install |
jimNCal wrote: | (quoted from post at 08:17:27 05/07/10) Chuck,
Can I use a 4th generation Sherman combo on an 8n? The tranny has the 15 spline inputshaft. Do you have a replacement inputshaft?
Thanks |
Back to top |
Hobo,NC Tractor Guru
Joined: 14 Jun 2007 Posts: 17001 Location: Sanford,NC
Posted: Tue May 15, 2012 2:35 pm Post subject: Re: Sherman Transmission Install |
[quote="Bob"](quoted from post at 20:55:49 05/06/10)
Bob I hope all is well your way I have not see ya post in awhile... |
Back to top |
