new sleeves in 1655 diesel
Cleon Couey
PostPosted: Thu May 13, 2010 5:24 pm    Post subject: new sleeves in 1655 diesel Reply to specific post Reply with quote
Having a little trouble installing new sleeves with o rings. I cleaned block until they would easily turn without orings. Using Crisco as a lube on the orings. Couldn't push them with hand pressure but would go in with rubber mallet and block of wood. Took it back out, orings okay. Shop manual says to use hand pressure only. What should I do?
JoeBob-IN
PostPosted: Thu May 13, 2010 5:27 pm    Post subject: Re: new sleeves in 1655 diesel Reply to specific post Reply with quote
Put them in with the hammer and wood and forget about them. Very few I have done pushed in with just hand pressure.
old1850d
PostPosted: Thu May 13, 2010 6:09 pm    Post subject: Re: new sleeves in 1655 diesel Reply to specific post Reply with quote
try using a differnt type of soap like dishwashing liguid ,apply this to the orings as well as the surface where they seat- double check the orings to make sure they are not nicked up slowly put the sleeve in the cylinder and when the first oring touches gently give the sleeve a 1/4 turn while pushing it in and then one more time for the bottom one you should have it . you will be able to feel it each time a oring snaps into place. Do not force them in. if you still cant get them you need to clean the cylinder more. Lyle
FoghornLeghorn
PostPosted: Thu May 13, 2010 6:22 pm    Post subject: Re: new sleeves in 1655 diesel Reply to specific post Reply with quote
Hmmm People must have been somewhat stronger when the manual was written.
Cas
PostPosted: Thu May 13, 2010 7:31 pm    Post subject: Re: new sleeves in 1655 diesel Reply to specific post Reply with quote
I know I was stronger then, but they still
sometimes needed a little persuation ie: piece
of wood and mallet.
DJM75
PostPosted: Fri May 14, 2010 2:40 am    Post subject: Re: new sleeves in 1655 diesel Reply to specific post Reply with quote
the main thing is they don"t go in too hard or you will roll the oring and it will leak. been there.
Shep VA
PostPosted: Fri May 14, 2010 4:00 am    Post subject: Re: new sleeves in 1655 diesel Reply to specific post Reply with quote
I always put the sleeves in the freezer overnight and pulled them out and slide them right in. As they warm up they expand and seal right in.
Works better in the winter when they stay cooler longer. If on a hot day in the summer, you have to work fast.
Just a thought
old1850d
PostPosted: Fri May 14, 2010 5:07 am    Post subject: Re: new sleeves in 1655 diesel Reply to specific post Reply with quote
we are talking about a motor with wet sleeves here
Shep VA
PostPosted: Fri May 14, 2010 11:46 am    Post subject: Re: new sleeves in 1655 diesel Reply to specific post Reply with quote
Yes, this is a 283 Waukesha diesel.
tom upton
PostPosted: Fri May 14, 2010 5:23 pm    Post subject: Re: new sleeves in 1655 diesel Reply to specific post Reply with quote
whatever you do DO NOT try to turn as you are putting in.
